iPod integration issue USA spec
Old May 11, 2010 | 03:59 PM
07gmoney35's Avatar
^ I couldn't get it to work at first either. I think what ended up working for me was setting my ipod to shuffle then holding the preset 4. Now when I push preset 4 it goes to shuffle.
Old May 11, 2010 | 04:06 PM
rrb_G's Avatar
I tried that.....at least I think I did it the way you are describing. when I would hold preset 4 it would just save over "genre or all songs" or whatever was mapped on there during set up.
Old May 11, 2010 | 04:27 PM
07gmoney35's Avatar
When I get off work (4:30pm pst) I will take a look at mine and see how exactly mine works. Ill post sometime around 5-5:30 with what I find.
Old May 11, 2010 | 04:34 PM
rrb_G's Avatar
thanks.
Old May 11, 2010 | 09:00 PM
07gmoney35's Avatar
^I think you must have received a faulty unit. I did the instructions over again and my random work just as the instructions say it should. I hold preset 4.
Old May 11, 2010 | 09:26 PM
rrb_G's Avatar
gmoney, thanks for checking on this for me. It makes me wonder if this is an issue with my radio, or the unit. Could it be because I had the Sat radio installed at the dealership?
It does a good job for a workaround aftermarket solution, however, I'm sending this unit back for a couple other reasons too.
1. Its too hard to go through the artists, albums etc. The only way to do so is to scroll, and its very slow. Would have been cool if you could somehow input a letter to narrow search.
2. I also have an iPhone 3gs, and I've got a new solution. I hook up through the av cables from the aux port, and put the mike adapter piece in line with that. That allows me to plug in and take advantage of the voice commands to selects songs, albums and even get song info. Sort of a poor mans ford sync.
Thanks for the input.
Old May 11, 2010 | 09:27 PM
rrb_G's Avatar
btw, when you hold preset 4, do you get a symbol on your display? Do you have nav, or the hard drive?
Old May 11, 2010 | 09:38 PM
07gmoney35's Avatar
^when i hold preset 4 it says "random on" or "random off." I have the pop up nav.
Old May 11, 2010 | 10:11 PM
rrb_G's Avatar
oh, so you must have an 07 coupe. Got it. That is a different radio all together. Thanks again. I feel good about my decision now.
Old May 11, 2010 | 11:47 PM
07gmoney35's Avatar
^I'm happy I could help, and yes I have a coupe.
Old Jan 26, 2011 | 09:40 PM
anrman's Avatar
What is a mike(mic?) adapter piece? What all the pieces and parts you are using to do this, i.e. interface pieces? Are you making 2 cables into 1? Yes, I'm an idiot. Keep this in mind when your responding.
bishop977
Audio/Video/Electronics
Jul 31, 2015 02:29 AM
itschuckster
Jul 25, 2015 08:07 AM
