Pioneer Avic D-3 help with gap? 05+ coupe pic request
Pioneer Avic D-3 help with gap? 05+ *Pics inside*
Hello guys i installed (myself) a pionner avic D-3 on my 05 g coupe and there is a gap at the top also it sticks out a lil bit. Can anyone post pics of how their D3 looks if you have one installed or help me solve the gap and sticking out issue?
Also if anyone tells me how i can upload pics to here ill post pics of mine installed so u guys have a better idea of what im talking about.
Check out some of the gap & trim install pictures in my gallery:
http://picasaweb.google.com/Avenger9...eat=directlink
To post pics, I highly recommend using picasa - it's what I use. But to just attach pictures to a post, use the "Manage Attachments" button below the main reply stuff.
Wow, let me guess, you used stock holes on the mounting bracket. You can do this, but if I remember correctly you cannot use all four stock holes and get good position/alignment. Good thing on the g's is you can play with different options outside the car as the mounting bracket and trim all come out.
Play around with different holes and see if that helps. Remember to test fit trim before putting it back in the car.
EDIT: I had the d3 and used a trim ring and I think 2 of the mounting holes to hold it in. Between the two screws and a snug fit at the trim ring, it was a solid fit and didn't move at all.
what trim is that and where can i buy it and you sureit will fit the D3? can you post a front pic of yours so i can see how it looks from front
Not mine, but it looks like every other flush-mounted one.
I believe the trim ring used is the Scosche one - check my DD shopping & resource list sticky for links.
But it'll end up looking about like this:
Is this the same trim ring on the pic because this one doesn't look like that one on the pic?
