double din HELP!!!
Old Jul 24, 2010 | 04:03 AM
  #46
Wrathernaut's Avatar
Gentle Manne of Leisure
You're forgetting the scosche trim ring.
Hit up my shopping list sticky for links and additional install tips and such.
And yeah, $800's good for the X920BT.
Old Jul 24, 2010 | 02:56 PM
  #47
teOx's Avatar
oh wow totally did not see that. picked up everything else from your list though, hopefully.
im guessing the trim ring can be put on after the install so i can still do everything else today right?
Old Jul 24, 2010 | 03:45 PM
  #48
A local shop may carry it or a similar product, on the 04's its a bit more complicated to get to where you need to put it.
Your choice though, you'll be experienced in getting to where it needs to go after the install, so it should go a lot quicker when you do put it in.
Old Jul 25, 2010 | 02:30 AM
  #49
teOx's Avatar
ah hopefully you or someone is still on to help. I'm about 6 hours into install and ran into a problem, after wiring the whole thing to the metra 7551 harness, decided to test it so we plugged it into the dash.
everything worked fine, tested the fade and balancing of each speaker, radio works, etc. but for some reason, i plugged my ipod using its stock white cable to the USB input that came with the x920bt and it doesnt play music. radio works still, and the ipod seems to be interfaced properly (shows artist, CD covers, songs, etc) just no sound. any ideas? want to get any issues sorted out before putting everything back.
Old Jul 25, 2010 | 03:34 AM
  #50
The USB cable doesn't carry the audio.
You can use a little 3.5mm male to 3.5mm male cable to connect the headphone jack on the iPod to the AUX input wire. You won't get video this way, to do that you should pick up the official pioneer cable for it.
Old Jul 25, 2010 | 07:56 PM
  #51
teOx's Avatar
guess thats how they getcha
Old Jul 26, 2010 | 01:49 AM
  #52
Yeah, the eBay copies of it don't have a high success rate either.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Picture Share
Feb 4, 2018 12:41 PM
Oregon13
Mar 1, 2016 12:06 AM
BfloG35
Oct 16, 2015 05:22 PM
