Can I cut the signal to two channels on a 4 channel amp?
Old May 25, 2010 | 12:54 AM
magnum97's Avatar
Not for the car, however I need to know before I install a toggle switch.
I've got a 4 channel amp running two rear speakers, and two speakers in the box of my pickup (running on the signal for the fronts). I'd like to be able to shut off the two exterior speakers. However I need to know if I will damage anything or hear any odd sounds by shutting off the input signal to two channels on the amp, while the other two channels are still going.
Old May 25, 2010 | 12:57 AM
06g35meister's Avatar
look into bridging the channels
Old May 25, 2010 | 01:05 AM
magnum97's Avatar
I want to have the ability to turn the outside speakers on/off at my discretion. I don't understand how bridging would serve that purpose.
Old May 25, 2010 | 01:06 AM
korban's Avatar
yup if the amp is capable of bridging then thats gonna be ur best route
Old May 25, 2010 | 01:17 AM
magnum97's Avatar
I apologize, I though i had mentioned that in the first post.
Old May 25, 2010 | 02:59 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
From http://www.audioenz.co.nz/forums/arc...hp/t-6089.html
As a precaution you could make up some RCA shorting plugs (wire linking centre pin to earth ring) for the unused channels.
Yup, good practice to use 'shorting plugs' on unused input sockets.
1) Eliminates noise pickup (form this possible source)
2) Keeps the socket clean (or cleaner anyway).
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Video Share
Sep 28, 2015 06:29 PM
