Speakers in Non-bose 2006 Coupe?
Old Jun 9, 2010 | 10:57 PM
Valgar's Avatar
Hello all,
I recently got a 2006 6MT Coupe non-bose, and it sounds like the pass. side front speaker is blown.
Thus, I am looking to replace the speakers. Could one of you G35 audio guru's tell me if the below speakers would be plug and play for my 06 non-bose coupe?
- Infinity Kappa’s 62.7I with ZEnclosures spacers (for rears)
- Infinity Kappa’s 60.7cs with ZEnclosures spacers (for fronts)
Thanks!!!
Old Jun 10, 2010 | 01:29 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Should fit, but haven't heard of anyone installing those particular speakers.
It's a lot of RMS to try and power with the stock radio though, I hope an amplifier is in your near-term plans, otherwise those will never sound as good as they can.
Old Jun 10, 2010 | 09:14 AM
Valgar's Avatar
Sorry, what do you mean by RMS?
I understand these won't be the best possible solution, I am simply want something easy to install that will work a sound better then my blown speakers
Also can someone comment on how hard it is to replace the coupe non-bose rears?
Old Jun 10, 2010 | 09:54 AM
RMS is how many watts they can handle continuously, as opposed to the "Peak Power" that cheap brands always slap on their "3000 watt amp! $300!" boxes.
If you have speakers designed for 75watts RMS but only feed it 12watts RMS, you're not going to be able to get optimal sound out of it.
Old Jun 10, 2010 | 10:09 AM
Valgar's Avatar
Thanks Wrathernaut,
So the speakers claim a range of 2-75 and 2-90 RMS, so as long as the get 2 RMS from the factory unit they will function, but likely sound crappy. So I guess now I just need to find out with the factory non-bose RMS is
Old Jun 10, 2010 | 10:35 AM
Valgar's Avatar
OK anther quick question, based on what I have read the stock speakers are 4 ohm, where as the Kappas I am thinking of installing are 2 ohm.
Is it not recommended to put in different resistance speakers ? what issues will I face and will they sound bad?
thanks guys!
nickmcc123
Lights
Oct 7, 2017 12:18 AM
mjfenix
Aug 17, 2017 05:49 AM
BlackGee35
Aug 12, 2015 08:41 AM
BlackGee35
Jul 21, 2015 07:24 PM
