How do I remove the tweeter sail panels?
Old Jul 6, 2010 | 11:57 PM
Ocuriel's Avatar
I have a 2007 Inf G35X Sedan. I want to start testing out different tweeters on the Studio on wheels system since the tweeters are too laid back for me.
To remove the sail panel, does the door panel need to come off 1st or do you just push back on the sail panel and slide up? I usually can figure it out but don't want to risk breaking anything.
What are the tweeters resistance?
I checked in a wiring diagram and found that the tweeters are running on the midrange drivers channels with a in line crossover, so keeping the same impedance is very important. If you don't, this will shift the range played.
Has anyone tried this? How was the outcome?
I may even consider swapping out the 3" midrange driver and the tweeters. Will probably have to do a custom crossover or something.
Any tips and info would be appreciated.
Old Jul 7, 2010 | 12:06 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
See:
http://www.psedog.com/cars/fsm/g35/sedan/2007/av.pdf - Page 115.
http://www.psedog.com/cars/fsm/g35/sedan/2007/int.pdf - Page 10.
Old Jul 7, 2010 | 11:11 AM
Ocuriel's Avatar
Nice! Thank you
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
