iSimple PXAMG with iOS 4 iPhone (SOLVED)
Here are the compatibility notes for Nissan/Infiniti on the PXAMG product. As long as your vehicle falls into one of these categories then you are good to go. Please feel free to email me directly with any questions.
Compatibility Notes - on vehicles that require the ISNI571 or PGHNI1 harness w/ the PXAMG
Vehicle MUST be either equipped with, or have the ability to support Satellite Radio
HD Radio support requires the purchase of the HDRT (sold separately)
Aftermarket Satellite Radio support requires the purchase of the ISSR11 & an SCC1 tuner (both sold separately
Radio must have a "SAT" button or have "CH", "CHANNEL", "CAT" or "CATEGORY" printed somewhere on the face of the radio to be compatible (except Rouge,see below). This is usually located near the Tune or Seek buttons.
Vehicle Specific Nissan/Infiniti Notes
Infiniti
In 2004-2007 Infiniti vehicles equipped with factory satellite radio, the satellite tuner will have to be disconnected at the tuner location in order for the PXAMG to work correctly.
2007 Infiniti G35 Sedan: Requires the ISNI572
Nissan
2007-2008 Nissan Maxima: Non-navigation radios use the ISNI572
Compatibility Notes - on vehicles that require the ISNI572 or PGHNI2 harness w/ the PXAMG
Infiniti
2007 Infiniti G35 Coupe: Requires the ISNI571
2007-2008 Infiniti G35 Sedan: Models equipped with navigation are not compatible
2008 Infiniti G37: Models equipped with navigation are not compatible
Nissan
2007-2008 Nissan Maxima: Models equipped with navigation use the ISNI571
2008 & Up Nissan Pathfinder & Armada: Models equipped with navigation are not compatible
2007 & Up Nissan Altima: Models equipped with navigation are not compatible
2009 & Up Nissan Maxima: Models equipped with navigation are not compatible
2009 & Up Nissan Murano: Models equipped with navigation are not compatible
2009 & Up Nissan Rouge: Vehicles equipped with radio part number "PY00F" are not compatible. This number can be found on the top right corner of the face of the radio.
2010 Nissan Altima & Sentra: Radios that have an "iPod MENU" button are not compatible
Infiniti
Nissan
Infiniti
Nissan
As long as your vehicle has the ability to support satellite radio from the factory you should be good to go. Also if you have factory satellite radio you will have to disconnect it at the tuner in order to use our iSimple interfaces.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
