Navigation won't stay up
Old Jul 31, 2009 | 08:02 AM
jwrape's Avatar
The G I'm buying has Navigation but you press the button and it comes up and then stay for just a second and then withdraws back into it's hiding place.
How do I fix this?
Old Jul 31, 2009 | 01:01 PM
Hurt_Locker's Avatar
I had a similar issue with my navigation. The fix was the plastic track guides on the sides were loose and preventing the full motion of the screen. So it would try and go up (or down for that matter) and not be able to complete the full motion and back up. Sounds as if your is being prevented from fully extending and senses something is in the way and goes back down. The windows do this too. My fix was to take apart the dash to get to the screen guides, which are exposed so all you need to do is remove the dash trim and tighten the white plastic guides on each side. They are held in place by a phillips head screw. After I tightened them I put a small amount of super glue on one side of the screw head to prevent them from backing off again, but still able to break loose with a screw driver if needed. I also put some grease on the track. Works like new.
Old Jul 31, 2009 | 01:04 PM
jwrape's Avatar
Excellent! Thanks for the info! That's a easy fix
Old Jul 31, 2009 | 03:36 PM
G15's Avatar
G15
cant keep it up eh? hmmm
Old Aug 2, 2009 | 07:02 PM
PeterUbers's Avatar
LOL... my thoughts exactly... navi-viagra?
Old Aug 5, 2009 | 06:51 AM
jwrape's Avatar
Well, as I was messing with it yesterday in the Walmart parking lot, it came up and stayed. You could visably see that it moved up a little further than normal when it stayed up. I played with all it's functions and set the Navigation to where we were going but then when I shut off the car to go in the bank it wouldn't come back up and stay again.
Gonna have to get in there and fix it this week, but at least I know all of it works
Old Aug 12, 2009 | 12:12 PM
jwrape's Avatar
Got it to stay up this morning all the way to work.... It's very spiratic. I am waiting on my Ipod Adapter to come in the mail before diving into the dash to fix it.
Old Aug 13, 2009 | 11:47 AM
Outrageous's Avatar
thats funny stuff.. Mine won't stay down... but I dont mind it up all the time.
Old Jul 30, 2011 | 01:46 PM
jwrape's Avatar
Still only comes up and stays once in a blue moon. I hardly every try it now unless it's really cold cause it seems to stay up more in the winter
Old Dec 25, 2011 | 08:24 PM
unwise's Avatar
Hey so Ive been having the same problem. Did A LOT of homework on it including researching the infamous TSB on the unit.
No you dont have to spend that much, nor do you have to go out and do a double din replacement (which would run into the 1k range after you get the dual climate control adapter, steering wheel adapter, and the actual unit)
When the screen pops up, the upper limit is determined by the number of revolutions of the motor, not the actual position of the screen. Over time, this limit seems to go out of adjustment.
To "trick" the limit, while the screen is moving up, quickly press down or tap on the screen so it momentarily moves downward then resumes raising as soon as you let go of it. When done correctly, the screen should raise fully; if you hold it too long, the screen will retract.
Now I dont know how long this will fix it, but mines been out of commission for months. Seems to work when its cold not when its hot, and now finally this year not at all. Did the fix mentioned above and ALL GOOD!
Falling in love with my g35 all over again
(NOTE: I'm going to post this in as many locations as possible since its been years since I've been looking for a fix.)
Thanks!
Old Jan 3, 2012 | 06:44 AM
jwrape's Avatar
Hmm, I'll try it again. But I have played with that thing over and over and it used to work every now and then, It has stopped all together for the past year. I'll see though
KruZZe
Feb 27, 2023 05:04 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
