I HAVE A MASSIVE CASE OF FEED BACK IN MY SYSTEM
I HAVE,
2 10W3
500/1 JL
450/4 JL
4 DIAMOND AUDIO COMP
EQX
AND STOCK HEAD UNIT
DOES ANYONE KNOW HOW TO GET RIDE OF FEED BACK THE SYSTEM GIVES OF @ LOW VOLUME??? AND THAT WEIRD NOISE FROM THE AMP WHEN YOU ACCLERATE??? PLEASE HELP
I HAVE,
2 10W3
500/1 JL
450/4 JL
EQX
AND STOCK HEAD UNIT
Feedback? Are yu talking about the kinid of noise you get when you place a microphone too close to a speaker? If you have no microphone you should not have feedback.
As far as engine noise, there are several possible causes. Diagnosing it requires a methodical approach.
Here's a great diagnostics workflow on Crutchfield's site:
http://www.crutchfieldadvisor.com/S-..._diagnose.html
Buzzing sound?..It's could be your ground(Amps), look for a better spot to drill your ground wire.
"Is simplicity best or simply the easiest"
as for the accelerate thing, yeah that's likely grounding issue... as for the noise when volume is low, either grounding or perhaps try turning down the gain on the amps, that may help.
2004 TB/W 6mtC. Sunroof only.
Bel Vector 985
Grounding Kit
Splash Guards
Custom Carputer
Custom FG Sub
Infinity KapPerf6.1, Ref 6002si, 5760 6-ch AMP.
30% Huper
Bel Vector 985
Grounding Kit
Splash Guards
Custom Carputer
Custom FG Sub
30% Huper
i had the same feedback. when i put my signal light on, you could hear the thump from the subwoofer. i relocated my LOC away from any metal, and shortened up my ground, and i was set.
