anyone got 4channel amp under pass seat?
Old Jul 30, 2010 | 06:15 AM
jdm-v35's Avatar
just wondering if anyone has put a 4 channel amp under their passenger seat (if theres room) and also if a 4 channel is worth it.
currently have kenwood ddx712, RE amp for 2 RE flat subs in 4080 boxes, boston pro 6.5 components up front and boston SE 6.5 coaxials in the rear
i also have a set of rainbow 3 way compenents i can out in but dunno if its worth it and dont know where to mount the 4" midrange speaker if so
Old Jul 30, 2010 | 08:20 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
There's a thread in here where somebody built a small midrange enclosure into the top cubby hole, takes some skill, but looks cool.
As for mounting under the seat, there's no airflow under there, and the seat above is going to prevent any heat dissipation. If you build a small box to make room around it with active cooling fans with ducting to the trunk or cabin to keep airflow it could be done.
Old Jul 30, 2010 | 08:59 PM
jdm-v35's Avatar
cool ty for the info. yea im just not really sure how much room there is. i havent had time to check yet.
Old Jul 30, 2010 | 09:16 PM
nar93da's Avatar
He's probably referring to me making the enclosure for the center channel. Check out my MS-8 thread.
I highly doubt you have room under the seat for an amp back to your topic. I'll have my interior out in the next few days so I can take some measurements for you?
Old Jul 31, 2010 | 04:32 AM
Just noticed you were referring to the side passenger seat and not the rear passenger seat.
You'd probably be fine there without any sort of ducting and such. Just make sure it is faced so that feet from behind aren't hitting the side with wires.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
doakley92
Sep 25, 2015 12:58 PM
