Radio lights not working? 03 sedan
Old Jul 31, 2010 | 03:29 AM
Chult86's Avatar
Dash works, AC/Temp window works. Even the red lights under the AC buttons work, but the radio buttons aren't illuminating.
Probably just a fuse? (please say yes, spent $1200 today already)
Old Jul 31, 2010 | 05:06 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Is the a/c stuck on 65? do they function?
Old Aug 1, 2010 | 01:44 AM
Chult86's Avatar
AC works just fine, as do all radio buttons, theyrejust not backlit
Old Aug 1, 2010 | 06:44 AM
The radio illumination doesn't have its own fuse, so it would be part of the circuit board that controls everything in the radio that went out.
Does the radio display dim when you turn the headlights on? If it doesn't then it could just be a bad connection on the harness going into the factory stereo. If it does dim, then it's definitely something bad in the circuit board itself, and likely needs to be replaced.
Good news with that is that most people who have upgraded to a double din setup have old ones sitting around they may sell. Just don't go posting a new want-to-buy thread in here, as that's against forum rules. But if somebody was to read this and PM you about it, that's just fine.
Old Aug 2, 2010 | 04:34 PM
spoolinupblue's Avatar
My BOSE headunit will be available this weekend.
Old Aug 3, 2010 | 10:54 AM
Chult86's Avatar
Nothing dims, not even the dash when I turn on the headlights. How would I go about fixing the harness?
Old Aug 3, 2010 | 11:24 AM
Just unplug the harness and reconnect it. Only problem is removing the radio just to do that.
Old Aug 3, 2010 | 11:31 AM
If nothing at all dims in the whole car, you could have bigger problems, but it means your radio circuits are probably ok.
It could be a simply relay that's gone out, or it could be the entire body control module. I don't have access to my manuals for another couple of hours, but with this problem you may want to post in the interior - lighting forum where somebody more familiar with this subject can weigh in.
arora_g35
Apr 16, 2026 02:52 PM
mike730
Jan 12, 2018 04:25 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
attarday
Jul 15, 2015 04:03 PM
