My Double Din Install
Old Jul 31, 2010 | 10:21 PM
Naylor07's Avatar
I just thought I would post up a picture of my install and my thoughts on the Metra Wire Harness (7551) vs. the PAC ROEM-NIS2.
First of all, I installed an Avic Z2 using the Metra harness. I picked this harness originally because it was simple. I have completed 5-6 installs and figured I could do the work for the more complicated harnesses, but who likes to do more work. After completing the install I had sound, and it wasn't extremely quite like some others have experienced, but it was not extremely loud. This means I could turn the unit up to the max 40 and with the AC full blast, it wasn't easy to hear over the AC.
I know the Bose amp is weak, so I thought about replacing it, but I figured before I went through all of that, I would give the PAC ROEM-NIS2 a chance since I had heard people had success. So I tore the dash back apart, undid the Metra harness and started sodering the new PAC ROEM-NIS2 in the unit. Once I turned on the unit, the sound output was 4-5 times what it was with the Metra unit. If I go above 20 now, it will likely blow the speakers out.
So, for my conclusion, I understand the Metra harness works for a lot of you and I am not degrading the product, I am just saying in my situation with a low sound output, the PAC ROEM-NIS2 did the trick.
Thanks for reading, sorry that the picture is a little blurry; it was dark and I didn't have a lot of time.
Old Aug 2, 2010 | 04:36 PM
spoolinupblue's Avatar
looks good.
I hope my Metra kit works for me.
Old Aug 2, 2010 | 04:37 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
It'll work, it just won't look as good as the JDM seen above.
gerbilunit's Avatar
looks great man
Old Aug 2, 2010 | 04:43 PM
Don't tell me that...lol
Old Aug 4, 2010 | 02:45 PM
djfarhan's Avatar
good work!
Old Aug 4, 2010 | 03:14 PM
I speaks the truth, but so long as the paint doesn't get scratched up real bad, few people will even notice with the bright touchscreen to distract them from the ugly gray buttons.
Old Aug 4, 2010 | 03:15 PM
Oh yeah, and I wish the OP could have recorded exactly how he'd hooked the harness up... and see if it was connected the way I recommend doing it or not.
Old Sep 9, 2010 | 10:50 AM
blue350gt's Avatar
I have a kenwood DNX5120 and first installed it with the 7551, output was very weak, I had to turn it near maximum to get it loud, it was loud enough but felt I was near the clipping point of the HU. I then switched to the PAC ROEM-NIS2, much much better, I turn the volume up half way and sounds just as loud with no clipping.
I would only recommend the 7551 if you have a HU with 4V or greater preamp outs.
Old Sep 9, 2010 | 01:19 PM
Naylor07's Avatar
Which harness are you referring to? I think I have pictures of both.
Old Sep 9, 2010 | 02:22 PM
Both would be good, I like having a large collection when people have questions about how something shoudl be wired up, or where something's located... but primarily how it was wired with the sound too quiet with the 70-7551.
But having a picture of the ROEM-NIS correctly wired can't hurt.
Old Sep 9, 2010 | 02:33 PM
06g35meister's Avatar
Holy crap ive been wondering about this the entire time!!! My radio is nowhere NEAR as loud as it was with the OEM head unit and i have the Metra kit, im going to order the other one ASAP and try it out and see if i get the same results.
God this thread is the best thing that has happened to me this week!
BTW DNX9140 is the HU i have, the preouts are like 5v, but seriously the radio is WEAK for what the OEM has.
Old Sep 9, 2010 | 05:14 PM
06g35meister, would you mind doing detailed pictures of how your harness is wired up? I had no volume issues with my car wired the way I recommend, so I'm trying to find somebody who can possibly video (so we can hear how quiet the quiet is) and show exactly how it's wired, because my 05 sounded just as loud as stock to me when I wired it up and video'd the result:
(And no, that isn't full volume at all, just loud enough to show that it's not quiet at all)
Old Sep 14, 2010 | 12:19 PM
Naylor07's Avatar
I am trying to track down the photos, not sure where I put them. But, I did have it hooked up the way you did in the video with a proper ground on all the ground wires. I soldered all the wires and taped them up.
I am unsure why the sound was lower than expected. Originally I had an Eclipse head unit and the sound was fine with it and the 7551 harness.
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
Crappyday
Aug 27, 2015 10:26 PM
EPG35
Aug 16, 2015 04:52 PM
Frankieg35
Aug 15, 2015 10:49 PM
itztwinki3
Aug 1, 2015 12:58 AM
