Something is wrong with my left speaker....need advice...
Old Aug 16, 2010 | 04:58 AM
acee's Avatar
Addict
Unhappy Something is wrong with my left speaker....need advice...
I have a 04 Coupe AT with the bose speakers when i play a cd while i drive and turn corners @ times my left speaker cuts off meanwhile if i play the radio every speaker works fine....it only happens when i play music cds, i was thinking of getting a aux input so i can play my ipod cause im tired of cds do u guys think that ill have the same problem as the cd issue? is there any way to fix this?
Old Aug 16, 2010 | 01:30 PM
GR6RR's Avatar
http://lmgtfy.com/?q=g35+headunit+speaker+problem&l=1
Old Aug 16, 2010 | 03:38 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
There's like two of these posts in the last two weeks.
The solution can be summed up in 5 words:
Do a double din conversion.
Old Aug 20, 2010 | 06:59 PM
skyvspecr34's Avatar
there is a lose point on the broad mine was doing the same if you are still covered on the car they should replace. i just got my fixed. if not there covered i seen ads on ebay and i think one on here for people fixing them for around 100. gl with evrything hope it works out for you
Old Sep 4, 2010 | 07:59 PM
Osa713's Avatar
Nice way to help out a fellow member. Too bad it doesnt fix the problem. I have the same problem. It only acts up when using the cd changer mode. That's what my Ipod adaptor is plugged to.
Old Sep 4, 2010 | 10:16 PM
spoolinupblue's Avatar
He is basically telling the OP how to completely fix the problem. We all know how bad the circuit board on these cars suck.
OP - $100 is a good deal if you have to pay for it and just want to keep the stock look.
My stock radio crapped out 2 weeks after owning the car. I had extended warranty on it and they replaced the radio to the tune of $1600.
Old Sep 5, 2010 | 03:20 AM
Replacing the headunit completely fixes the problem.
Old Sep 10, 2010 | 08:33 PM
acee's Avatar
Addict
thanks for all the advices yeah i stood with the stock headunit and got my ipod adapter n works like wonder its connected to my sat button n both speakers work well...no problem no ...im guesssin the cd mode is still da same but im more of an ipod person...so it works for me regardless,...
Old Sep 11, 2010 | 05:30 AM
Well, I hope the stock headunit doesn't continue to go out on you, otherwise that iPod adapter will be connected to a paperweight.
Old Sep 21, 2010 | 01:54 AM
Osa713's Avatar
Funny my buddy has an aftermarket headunit and still has that problem
Old Sep 21, 2010 | 01:55 AM
Osa713's Avatar
I have an ipod adaptor that connects to the cd changer and i still have the problem
Old Sep 21, 2010 | 03:32 AM
So you're saying that your friend's left speaker would only fail on CDs with the factory unit, but work with the radio, then installed an aftermarket one, and CDs continue to fail on the left speaker, but not when listening to the radio?
Don't think so.
If his left speaker is failing regardless of source, that's an entirely different problem from the OP.
Old Sep 21, 2010 | 03:33 AM
Which is an entirely different problem from the OP. If it fails on one source - headunit's bad. If it fails on all sources, headunit OR speaker OR amp might be bad.
Old Sep 22, 2010 | 08:10 AM
Osa713's Avatar
Does anyone have a link to the where I can send my send My HU in to get the circuit board fixed? Or does anyone know what needs to be re-soldered? Maybe I can do it myself.
Old Sep 22, 2010 | 08:12 AM
Osa713's Avatar
His speaker fails only with the ipod connection to the aftermarket radio.
Do you know what is causing the original problem?
Don't think so.
