Stock CD player giving me problems.
Old Oct 15, 2004 | 05:06 PM
roneski's Avatar
Devil's Advocate
When I play a CD the left channels both front and rear sound very low and distorted. But when I play the radio everything works fine. Anyone experienced anything like this?
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-- Abraham Lincoln
Old Oct 15, 2004 | 05:27 PM
dave's Avatar
Re: Stock CD player giving me problems.
Mine is doing the same thing. I've seen here that other people had the same problem.
I made an appointment with my dealert to take a look at that (and a creaking noise and change the oil).
2004.5 DG/G 5AT Coupe with all options
Sidemarker turnsignal mod
GroundingGear™
2003 Yamaha YZF600R
Old Oct 15, 2004 | 06:04 PM
roneski's Avatar
Devil's Advocate
Cool, good to know that I'm not the only one I guess. I'll have them look at it when I go for my 7500 mile maintenance.
-- Abraham Lincoln
Old Oct 15, 2004 | 06:14 PM
Birds04G35's Avatar
YES, hopefully its a defect or something, my front left speaker is all distorted at times. I thought i had blown the speaker but maybe not.
Old Oct 16, 2004 | 03:04 AM
Raznips's Avatar
its definatly a defect.... i dunno what it is... someone else i talked to about it said their face plate was the messed up part. My dealer just ordered me a new door speaker (the next day my rear left side went too).... im going tommorow to have them put in the new speaker.... even tho i think im prolly gonna end up having them do other stuff too since my sound has finally come back in the left side.... im gettting weird creeks too from between the door and the panel on the inside.... maybe its all related. When i hit my brakes hard before it would kick back in and if i hit the left side of my headunit. The other day i slammed on my brakes (locked in at 60mph) cause a yard work truck with a huge trailer full of lawn mowers and stuff changed lanes while i was beside the huge metal trailer.... since then my sound has been great.... obviously this is a problem with a run of headunits. Im guessing all of u guys have 2004.5's too (the guy with 7500 mile coming up). Mine has about 4500 miles and is doing this same thing. Im glad there was a post about this because tommorow if im at infiniti and say something and they say no one else has this problem i can show em this thread
2004 Black on Black g coupe 6spd.... aluminum pedals, clear corners, z tube, and pop charger. soon to have 19" volk gt-c's and PIAA xtreme whites in the clearance and corners
Houston Texas
Old Oct 16, 2004 | 02:59 PM
roneski's Avatar
Devil's Advocate
Yeah, it's definitely intermittent. Mine started working again all of a sudden. I freakin hate that. It'll always work when you take it to the dealer.
-- Abraham Lincoln
Old Oct 16, 2004 | 06:03 PM
blksnake's Avatar
Guys/Gals,
I experienced the same problem with my non-BOSE headunit today. The driver (left) side speaker output was very low compared to the passenger (right) side when listening to the CD. The radio output levels are fine.
I preformed the following to diagnose the problem:
1) Checked the balance setting.
2) Reversed the inputs to my amp and verified the problem is with the headunit.
3) Switched to another disc in the changer with no positive outcome.
4) Verified the radio output was okay.
5) Ejected all 6 discs from the changer and reinserted one disc.
<font color=red>The single disc I inserted played fine!</font color=red> Perhaps when I ejected all the discs the headunit reset itself. This leads me to conclusion that this is not a loose connection issue, but a problem inside the headunit.
I don’t want to do this on a regular basis, but I’m glad everything is working okay once again.
Let me know if this solution works for you.
BLKSNAKE - '04 G35 Coupe
http://hiddensub.info [img]/w3timages/icons/laugh.gif[/img]
Old Oct 16, 2004 | 07:02 PM
roneski's Avatar
Devil's Advocate
Link to similar post in G35 coupe general forum.
https://g35driver.com/forums/showfla...=5&part=2&vc=1
-- Abraham Lincoln
Old Oct 16, 2004 | 07:05 PM
etang789's Avatar
Yes this problem has been brought up many times i believe that this should be a TSB or something make it a sticky how people can sort this out because i believe its the Headunit problem because it plays find with radio...and some people went and exchange their headunit fixed it for awhile then problem came back again...
i have the same problem brembo helps
Old Oct 16, 2004 | 07:11 PM
roneski's Avatar
Devil's Advocate
Just tried Blksnakes fix and low and behold... it works!!!
Thanks for the tip man. Still kind of an odd problem though.
-- Abraham Lincoln
Old Oct 24, 2004 | 08:12 AM
tekknikal's Avatar
ive had this problem for a while and for me, whenever you eject and insert a cd it plays fine- no need to eject them all. i think its a bad connection.. i wonder if anyone has a spare head unit to open and examine.. apparently getting a replacement wont solve the problem.
Old Oct 25, 2004 | 07:07 PM
gone's Avatar
i have the same problem with the bose headunit
red 6mt prem navi
Old Nov 22, 2004 | 12:34 PM
JediRacer's Avatar
I'm currently having this exact same problem with my non-bose head unit.. AGAIN. This happened to me once about 6 months ago. The dealer replaced the head unit. Now it's doing the same thing again. The left speakers are low and extremely distorted. Am I going to have to take it to the dealer every 6 months for a replacement head unit?
Old Apr 9, 2005 | 03:34 AM
n1cK's Avatar
G35 6MT
Angry me too...
i know this is kind of an old thread, but now this problem is happening to me! argghhhhh! is there any solution to this at all?
Old Apr 9, 2005 | 04:56 PM
dave's Avatar
The only solution I have heard of is a temporary one... Take it to the dealer and have them replace the head unit. But unless they update the head unit, it will happen again.
I had them replace my head unit, and it is fine for now.
