Need help w/ Jl 500/1 and LOC
Old Oct 16, 2004 | 08:26 PM
ChuckP's Avatar
I amp going to be adding a JL 500/1 and 2 eclipse 10" Alum to the factory clarion HU, w/ premium bose sys. My question is, I know i need an LOC, but i dont know which i better, PAC or Peripheral? Also, how many channels, 2 right? Which LOC do you guys recommend and should i use an adjustable one, like the SNI-35 for example. And last, do i need to run a remote turn on line for that amp?, i read that the JL 500/1 has an auto on sensing feature, but some people say its crap. If i do need to run a auto on line, what bose line in the trunk do i splice? I got a Coupe w/ premium bose sys. Thx alot
Old Oct 17, 2004 | 09:26 PM
ChuckP's Avatar
Re: Need help w/ Jl 500/1 and LOC
Do i need a LOC , the JL 500/1 has a high/lo setting for line in, i just need to know how to convert speaker wire to the jl input rca's?
Old Oct 17, 2004 | 10:32 PM
GoSooners's Avatar
I too heard from a friend that auto-sensing features on car audio amps are usually crap. But connecting another remote wire shouldn't be to hard. Just tap into the blue/white wire for the Coupe. I don't know what color it is for the Sedan but just do a search on here. I'm currently using a Navone LOC and have no problems, no noise. There are some guys on here using Peripherals without any problems/noise as well. Now if you don't want to use a LOC, you can go to any authorized JL Audio dealer and they should have a cable that is wire-to-RCA. JL Audio makes it but you can make your own by just cutting up any pair of RCA cables. Just make sure you set your amp properly with either route.
Black 5AT Coupe, Navi, Falken Koblenz 19", HKS Legamax Exhaust, ZTube/Stillen, Grounding Kit, RSR Springs, Tokico DSpec Shocks
Old Oct 18, 2004 | 08:47 PM
ChuckP's Avatar
Hey thx GoSooners, is there any advantage or disadvantage to using a Wire-RCA vs an LOC? how will the sound quality both ways?
Old Oct 19, 2004 | 12:05 AM
GoSooners's Avatar
I haven't really tested both ways but my original plan was to go with wire-to-RCA but my JL Audio dealer ran out of those cables at the time I was doing my install and I didn't want to cut up my Monster RCA cables so I just went ahead and ordered a LOC. I really have nothing to compare to but I honestly don't think my sound quality could be any better than it already is.
I would have to say though, that with a LOC, if it's not from a reputable mfr, you could have interference problems or humming due to a bad circuit within the LOC. If you go the other route with the wire-to-RCA, you may have to purchase some female to male RCA couplers if your amp will be far away from the wires you tap into.
Old Oct 19, 2004 | 10:29 AM
Rudy's Avatar
Sound Advice
I have put in the JL wire to RCA piece and have not had any problems.
Do you hear me?
Old Oct 19, 2004 | 07:36 PM
ChuckP's Avatar
so i can just hack both ends on one side of my RCA wire, splice them to my speaker wires, set my amp to high level input and im good to go right?
Old Oct 19, 2004 | 10:15 PM
GoSooners's Avatar
Yes, but be sure to tap into the front or rear speakers and not the 6x9s so you can get better quality.
Black 5AT Coupe, Navi, Falken Koblenz 19", HKS Legamax Exhaust, ZTube/Stillen, Grounding Kit, RSR Springs, Tokico DSpec Shocks<P ID="edit"><FONT class="small"><EM>Edited by GoSooners on 10/19/04 07:18 PM.</EM></FONT></P>
Old Oct 20, 2004 | 01:12 AM
ChuckP's Avatar
nice, thx a lot
broke_as_ajoke
Nov 6, 2015 11:49 PM
yosip1115
Aug 26, 2015 10:46 AM
Thunderaan
Jul 22, 2015 07:40 PM
GoSooners
Mar 22, 2004 02:05 PM
