AMP install link?
Old Oct 17, 2004 | 07:47 AM
GBoy's Avatar
AMP install link?
Was wondering if anyone new of a link to install a 2 channel
AMP to power my front door speakers. I drive a sedan and changed out the front door speakers along with the tweeters
about a year ago. This past weekend I was in Circuit City
and they had a special on all AMPS do picked up the Infinity
for 179$, where would be the best place to install the AMP....and do I have to get the power from the battery or
can I get power that is going to my existing AMP (stock)..
Thanks
GBoy
2003 Sedan/Black/Black
Coupe suspension
Z pipe/KN filter
Grounding kit/Clear corners
Old Oct 17, 2004 | 02:21 PM
roneski's Avatar
Devil's Advocate
Re: AMP install link?
Here's an amp install DIY link, you'll find lots of good info there.
https://g35driver.com/forums/showfla...&sb=5&part=all
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-- Abraham Lincoln
Old Oct 18, 2004 | 06:48 AM
GBoy's Avatar
Thanks for the link, where would be the best place to put
my additionla AMP on my sedan?
GBoy
Coupe suspension
Z pipe/KN filter
Old Oct 18, 2004 | 01:09 PM
GBoy's Avatar
and would I be able to get the power from my existing amp
or do I have to go to the battery...
GBoy
Coupe suspension
Z pipe/KN filter
Old Oct 18, 2004 | 04:57 PM
roneski's Avatar
Devil's Advocate
Depends, I'd definitely recommend running a cable to the battery because the stock wire is only like 14 guage. But you can give it a try and see if you are happy with it.
I ran 8 guage back to the battery for my basslink and it wasn't too tough to get from point a to point b. Anything larger than that though and you'll have to modify some of the trim to accomodate the larger wire. I think that running the wire to the batt is worth it because it gives you the freedom to expand in the future if you want. It took me about 2 hours, and I needed right about 20 feet.
I'm not sure about how large the Infinity amp that you bought is, but I'd probably try to fit it down where the stock amp sits. If not there then just mounting it to the back seat is a popular option.
-- Abraham Lincoln
nettcar
Aug 25, 2024 11:59 PM
hdmark
Apr 29, 2019 04:31 PM
Bean_VQ35DE
Aug 22, 2015 09:56 PM
CrazyLogic219
Aug 13, 2015 06:40 PM
Thunderaan
Jul 22, 2015 07:40 PM
