HELP! Audio gurus please come in. Just got new system installed!
Old Oct 7, 2010 | 11:07 PM
hye_G's Avatar
Exclamation HELP! Audio gurus please come in. Just got new system installed!
Hey guys just got a new system installed.
Infinity Kappa Speakers front and rear as well as an Infinity Kppa 10 sub, and Kappa FIVE full system amp.
Just picked up the car.
There is an extremely loud buzz.hiss coming from the speakers and seems to get worse as i accelerate the car. Sound goes away when head unit is turned off.
Another issue. It seems I lost all my mids. Im assuming theres a way of setting up all that through the head unit but there are a million settings and i dont know which to use.
PS. Im running a Pioneer AVH-P4100 Head Unit
PLEASE HELP!! Thank in advance.
Old Oct 7, 2010 | 11:44 PM
Unleaded91's Avatar
Congrats on your install..
I am not a car audio expert, but I think you probably need better grounding of your components.
I hope wrathernaut and eggyhustles chime in.
Old Oct 7, 2010 | 11:49 PM
ilovez33's Avatar
It is a poor grounding issue.
Old Oct 8, 2010 | 12:33 AM
eggyhustles's Avatar
Ground
Old Oct 8, 2010 | 12:35 AM
BigVicG35's Avatar
Just take it back to the shop and let them know. They took care of the noise for me
Old Oct 8, 2010 | 12:50 AM
NMG-4's Avatar
let the shop faint the problem.
Old Oct 8, 2010 | 11:20 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
I'd be weary of any shop that left a car with whine like that.
Was this a friend who had installed a sub in his car as his only experience, perhaps?
There's way too many things at this point that could be the problem
Could be a bad ground, or could be waaaay too small gauge wire used as well, with an install apparently as bad as you got I'm not ruling anything out.
I'd say take it somewhere reputable if a friend did it, or make the shop do what you payed them to do, if you had it done by a shop.
Old Oct 8, 2010 | 12:15 PM
hye_G's Avatar
i had a local shop do it. i will be taking it back to fix the issue.
are there multiple ground locations? anything thats a quick fix?
also do you guys recommend certain EQ settings to get my levels just right. seems like my highs are too high and mids are way too low.
thank you so much for the help guys. much appreciated.
Old Oct 8, 2010 | 12:31 PM
06g35meister's Avatar
One other item to check is if they wired the audio signal cables and the power on the same side. That will cause whine. They should have the power cables (assume at LEAST 4 gauge, if they did 8 you will have trouble) on the passenger side and the audio on the right side.
Otherwise its a grounding issue.
As far as tuning, just play with it until you like it, i have played with mine for 6 months and almost have it dialed in, the one they gave me at my install shop wasnt right for me, i like more bass and lots of treble with lower mids.
Old Oct 8, 2010 | 02:14 PM
NMG-4's Avatar
they probably ran the audo wire and power wires on the same place, to save some time.
Old Oct 8, 2010 | 02:59 PM
If you have audible whine at an inch of separation, you'll have the same whine with 2 feet of separation. If you have to separate your signal that far, you've got wiring problems that if you just ignore and treat the symptom by moving wires further apart, you're doing damage to your entire system instead of treating the cause - bad ground, bad power or a poor connection elsewhere in the system.
4 gauge minimum, yes.
Old Oct 8, 2010 | 09:14 PM
hye_G's Avatar
hey guys heres a pic of the amp settings. anything i should change or adjust?
Old Oct 8, 2010 | 10:24 PM
take that to a pro to be tuned
You have the gain jacked up all the way smh
And you're low passing the sub @ 32 hz when it should be low passed @ 80hz
Old Oct 9, 2010 | 12:43 AM
hye_G's Avatar
you guys le me know and i can adjust the levels. since the guy installing my stuff doesnt know what hes doing i dont know who else to take it to.
Old Oct 9, 2010 | 04:17 AM
Here's where I'd start with that amp.
LPF 80hz.
Rear and Front at FULL.
All gains set to min until you do basic setting of proper levels.
Boost on sub channel to 0dB
HP on sub channel to 80hz
