Single sub wiring help
Old Oct 19, 2004 | 11:25 PM
DougsfastZ's Avatar
I'm just starting research for my system for the coupe. I'm getting a JL Audio 10w6d2 in this: https://g35driver.com/classifieds/pa...x=13&item=2720 enclosure. I have two older amps from my Honda, and I want to use one of them. The amp is a JBL GTQ400 and those specs can be found here:http://www.jlaudio.com/subwoofers/pdfs/W6v2_MAN.pdf.
The sub can handles a ton of power, looks to be up to around 600 rms. The amp has a rating of 200w @ 4 ohms (2 channels). My guess to hook everything up right is to run the amp, 2 channel input, in bridged mode to the sub. I want to provide as much 2 ohm power I can. Can I assume that the amp can supply 400 watts at 2 ohms? Can I run this amp in 2ohm's? Do I run the sub in mono?
Thanks for the help,
Doug D
04 Black on Black Coupe, 6 speed, Nav, clear corners, 14.39@97 in the summer heat
Old Oct 19, 2004 | 11:50 PM
limeg35's Avatar
Re: Single sub wiring help
i didnt find any spec on the amp, but if it can do 200x2 at 4ohm stereo? if you bridged that amp, it should be at 400x1 at 4 ohm, not sure if it can take 2 ohm mono(bridged) load.
if you only getting "one" dual 2 ohm sub? you can only hook it up either 1 ohm (+/+,-/-) or 4 ohm(+,-/-/+)! (someone correct me if i am wrong [img]/w3timages/icons/frown.gif[/img])
03 coupe 5AT DG/G premium,performance,
AVIC N1, Volk GT-7
Old Oct 20, 2004 | 08:46 AM
DougsfastZ's Avatar
Forgot to add the link to the amp. http://manuals.harman.com/JBL/CAR/Ow...0-400%20om.pdf
Just not sure how to hook this up properly.
Doug D
Old Oct 20, 2004 | 10:50 AM
mark5's Avatar
how much did you pay for the sub? i'm shopping for the same thing
Old Oct 20, 2004 | 10:55 AM
DougsfastZ's Avatar
I haven't gotten it yet. Cheapest I found was $300.
Doug D
Old Oct 20, 2004 | 12:45 PM
limeg35's Avatar
its a 4 channel amp?...it can only do 200x2 max, cus its at bridge mode already, it wont run at 2ohm bridge mode,! i will lQQk for someohter amp for that badboy (w6) [img]/w3timages/icons/laugh.gif[/img]
AVIC N1, Volk GT-7
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
Learned Hand
Oct 1, 2015 09:02 AM
9tray turbo
Sep 29, 2015 10:22 PM
