Looking for a little advice
Old Oct 22, 2010 | 04:45 PM
alexh521's Avatar
Ok so ive looked around and read that w/bose audio the G is lacking in the midrange sound. I was wondering if i replaced it with this... would that give a better overall sound while producing more bass than the stock sub did?
http://cgi.ebay.com/NEW-O2-AUDIO-8-MIDBASS-FREE-AIR-SPEAKER-MID-BASS-SUB-/350396297750?pt=Car_Subwoofers_Enclosures&hash=item51953f3216
Ive never done anything care audio related so what kind of amp should i run with that?
Old Oct 22, 2010 | 05:24 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
If you looked and read around a bit more, you'd see that the major culprit for horrible sound is the amplifier.
The EQ in the amp is still going to cut the bass way down whenever the volume goes up regardless of what sub it's powering, so you're not really going to get any more bass as long as you're powering the sub from the Bose amp.
I have no knowledge of that brand, but my knowledge in such matters is definitely quite shallow, however, you're going to need either an amp that can take differential-balanced inputs (JL and a few others do this) or something like the MTX REQ to unbalance the signal before putting it into a different brand of amp.
That sub only takes 100w RMS, so a simple amp like this (with the gain not all the way up, of course) would be fine: http://www.woofersetc.com/p6417/Di17...-Amplifier.htm
Old Oct 22, 2010 | 05:59 PM
alexh521's Avatar
Now what if i kept everything stock and upgraded the amp? Better or worse?
I am aware that no amp will fit in the stok location and im assuming moving it wont be overly difficult.
Old Oct 22, 2010 | 06:18 PM
Better.
There's actually a decent amount of room at the stock location, just build a thin MDF shelf and mount it.
Compare the two pictures, just ignore my amps in the second picture.
See how much room is between the amp and the sub? That's just empty space behind the carpet. You've got room to build a thin shelf and mount it up, easily. Just make sure you have empty space for the hot air to go above the amp, but a D-class amp, running beneath it's RMS should run quite cool.
Old Oct 22, 2010 | 06:32 PM
alexh521's Avatar
What if i replaced the Bose amp entirely with a 6-channel or whatever the bose system requires?
Old Oct 22, 2010 | 08:11 PM
Definitely better. A smaller five or six channel would fit that spot.
Old Oct 22, 2010 | 08:35 PM
alexh521's Avatar
well what about this for a 5 channel? http://cgi.ebay.com/TIS-700-WATT-5-CHANNEL-CAR-AUDIO-AMPLIFIER-AMP-KIT-/350405288285?pt=Car_Amplifiers&hash=item5195c8615d
Old Oct 22, 2010 | 11:32 PM
nar93da's Avatar
That amp won't work because it won't accept the balanced inputs from the Bose headunit. Your going to have to look at Arc Audio, JL Audio, Older PPI PC class, Zapco and I'm sure someone else can name more amp companies that I forgot that make amps that accept balanced inputs.
Here is what I would mount under the rear deck.
http://mobile.jlaudio.com/products_amps.php?amp_id=596
Old Oct 23, 2010 | 05:26 AM
Originally Posted by alexh521
well what about this for a 5 channel? http://cgi.ebay.com/TIS-700-WATT-5-C...item5195c8615d
Wouldn't accept the inputs and probably worse quality than the Bose amp.
Old Oct 23, 2010 | 01:28 PM
alexh521's Avatar
hmm. to me everything in the Bose audio system seems fine but imo opinion its lacking in the bass and midrange and im looking for the easiest way to solve that while using the stock sub location. Should i go ahead and just replace the bose amp with a better 5-channel or should i get a sub that will fit in the original location and get a mono amp?
Old Oct 23, 2010 | 02:00 PM
Better option is a new, good 5-channel, but the cheaper option is the mono amp.
Old Oct 23, 2010 | 05:28 PM
alexh521's Avatar
hmm. well my budget is around $200
Old Oct 24, 2010 | 11:58 AM
smittyrock's Avatar
You can still find some PPI amps on ebay. I have a PPI I've been using since the 90s and installed it in my 04 coupe without any real issues. I used the aux power socket fuse to supply my remote voltage. The wire listed in the sticky was a tad low to turn on the PPI. Excelent amps and probably underrated as far as listed wattage goes.
Old Oct 24, 2010 | 09:27 PM
nar93da's Avatar
You could try to find an old PPI PC650 or PC6600. Very good amps and they will accept the balanced inputs. Your probably not going to get one for $200 though. Do you plan on using all the stock speakers if you upgrade to a 5/6 channel amp?
Old Oct 25, 2010 | 03:50 AM
Yeah, right now, best advice is to keep saving.
That $200 budget will only get you crap that will have to be replaced later.
