Need iPhone Integration
Old Oct 25, 2010 | 10:57 PM
richardcvan's Avatar
I have a 2005 G35 coupe with Bose sound stereo and stock navigation and i need a iPhone/iPod integration with steering wheel control.. can someone point me in the right direction?
Old Oct 25, 2010 | 11:07 PM
Unleaded91's Avatar
USA Spec PA15-nis is your friend...
This unit is plug and play behind the Bose stereo..also does steering wheel control...
Old Oct 25, 2010 | 11:09 PM
Unleaded91's Avatar
If you don't want to remove the stereo, you can get the one that plugs to the SAT receiver in the trunk if you have SAT
Old Oct 25, 2010 | 11:24 PM
would the one plugged to the back capable of steering wheel control? and how would i know if i have SAT
Old Oct 26, 2010 | 12:04 AM
Unleaded91's Avatar
I am not 100% sure because I don't have it but it will probably work..
You will know you have sat if you have the sat button on the radio..And when the sat button works(I mean, gives you the ads)
Old Oct 26, 2010 | 03:49 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
PA15-NIS and PA15-INF are the same except for where they plug in.
As an '05 sedan, your sat connector is pretty easy to get to as well, just pull the rubber ring out of the pass-through door, and reach down and to the passenger side, you'll feel it.
Here's a little diagram to show you what you'll be feeling back there.
You can connect it and test it that way in about 2min or less. Then when you feel up to it, you can route the wire through the car to your location of preference. Not sure how long the wire on the PA15 is, if it's about 6 feet, you can just run it under the rear seat, along the hump and into the center armrest cubby easily.
Old Oct 26, 2010 | 11:38 AM
I have a coupe though.. would my connector still be in the trunk andi guess i dont have sat
i have pty/cat... so i guess i got to hook it up to radio
Old Oct 26, 2010 | 01:19 PM
Connector still in the trunk in about the same spot, but you have to remove some of the carpeting, if I recall correctly.
Old Oct 26, 2010 | 05:18 PM
have any idea where to get one cheap? lowest i found is $150
Old Oct 26, 2010 | 06:19 PM
Marketplace on this board is about the only place.
Old Oct 26, 2010 | 07:14 PM
is there any special instructions if i have a stock navi?
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
the93owner
Sep 27, 2015 05:23 PM
