question about connecting rca to bose harness
Old Nov 10, 2010 | 07:24 AM
aznvictobear's Avatar
so i got a jl 1000.1 v2 04 coupe with bose. i dont understand how to connect the blue harness to the amp via rca cables. i read the diy sticky how to connect a sub and i dont know how to splice the harness cables to rca. i went to an audio shop and they said that to splice the harness and rca and solder them together wont give such a good connection and they recommended to get a loc to do that. they had 2 loc. 1 had the remote connection for $49 and the other loc did not have the remote connection but was for $5. so which road is better?
Old Nov 10, 2010 | 08:36 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
The JL doesn't need a LOC. It can take speaker-level inputs, and you're better off tapping the wires before the bose amplifier of suck messes with the audio signal anyway, so there's 2 reasons not to install using an LOC.
To tap it, just either cut an RCA cable in half and connect the wires (soldering does, in fact give you a damn good connection when done right) and connect those RCAs to the line level input on the amp.
Old Nov 10, 2010 | 02:41 PM
Alright Fosho for the help. Do you have a pic of the RCA soldered to the harness. So I can get a sense o how it is done right.
Old Nov 10, 2010 | 03:22 PM
For the remote does it matter if it soldered to the positive or negative RCA
Old Nov 10, 2010 | 05:18 PM
Uh, no pictures, it looks like wires soldered together. Use your imagination.
Which remote? Remote amp turn on? You connect that to the amp power signal wire, not an audio signal.
Old Nov 10, 2010 | 11:19 PM
nar93da's Avatar
Here are some pictures I took of when when I was installing my gear. The wires you need to tap into are the one's in the picture with the outer shell, with the 2 conductor's inside with the shielded wire.
Just make sure you go positive to positive and negative to negative. I made my own RCA harness using Gepco 6180ez which has a shield wire in it also. I soldered the wires together but didn't take pictures of it because, well it's soldering! If you don't feel comfortable with wiring you should just take it to someone who does.
EnCr1pt3d
Jul 8, 2019 02:48 PM
willdogs
Dec 8, 2015 11:32 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
BlackGee35
Jul 21, 2015 07:24 PM
