viper 5902?
Old Nov 21, 2010 | 02:02 PM
jin22gt's Avatar
Can I still open the windows with the I-key? I'm assuming that I could still use the keyless entry system on the door? But is the viper alarm integrated to the keyless system? Or would the alarm go off?
Old Nov 21, 2010 | 02:14 PM
Silencer_0's Avatar
Yes, you can still hold down the unlock button on the intellikey to lower the windows. The keyless entry becomes kinda useless. Pressing the button on the door unlocks them, but it doesn't deactivate the viper alarm, so it'll go off if you open the door.
Old Nov 21, 2010 | 02:39 PM
jin22gt's Avatar
Thanks for the info guys.
Im planning to get the back up battery, tilt sensor and the window break sensor with the viper 5902.
Somebody said if u hardwire the 5902 to the windows it should work without a module. Is this true?
Old Jan 31, 2011 | 11:40 PM
psycobusa's Avatar
Originally Posted by Silencer_0
I have the 5902 with my intellikey. No 03-07 coupes came with a push button, just the ****, not sure about sedans. All the functions with my intellikey still work, though I never use that key fob anymore. You'll need the bypass module for the remote start, that way, you don't have to leave any keys inside.
on the i-key cars, if the bypass module makes the car think the oem keyfob is inside when it actually is not, will a thief be able to push the button on the door and unlock it? or do you still need to have the oem fob with you?
Old Feb 1, 2011 | 12:26 AM
Silencer_0's Avatar
You still need the fob with you.
g.spot
May 9, 2016 10:54 PM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
NemesisGee
Aug 11, 2015 07:10 PM
