JL Audio W3v3
Old Nov 20, 2010 | 12:32 AM
aix37's Avatar
JL Audio W3v3
I just picked up a 10 inch W3v3. Looking at the specs, it says I need 500 watts with a nominal independence of 4 OHM. Would a JL Audio 500/1 amp give out enough power the sub? If not, any recommendations on what amps would be good for this sub?
Thanks
Old Nov 20, 2010 | 02:28 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Yes it would be fine.
Old Nov 20, 2010 | 01:34 PM
aix37's Avatar
Would the JL 500/1 be over killing it? Can I get away with a JL 250/1?
Old Nov 20, 2010 | 04:43 PM
eggyhustles's Avatar
It's a 500 watt sub and you're asking if 500 is too much.
No.
The 250 would also be fine.
Old Nov 20, 2010 | 04:48 PM
If you're running sealed, I'd highly recommend doing the 500/1 over the 250/1.
Old Nov 20, 2010 | 07:16 PM
Ported + the 500/1 would be nice
It'll gain you 6db
Old Nov 21, 2010 | 11:12 PM
aix37's Avatar
Thanks for the advice guys. I think I'm going to go sealed, as I like SQ over loud bass. Am I am able to get any 10 inch box off of websites like ebay, or should I build a custom box specifically for the sub. I found a ebay listing for a 10 inch sealed box for 25 bucks, which is pretty cheap. What you guys think?
http://cgi.ebay.com/10-INCH-SUB-BOX-REAR-FIRE-SUBWOOFER-SEALED-ENCLOSURE-/230551851837?pt=LH_DefaultDomain_0&hash=item35adf6133d
Old Nov 21, 2010 | 11:39 PM
aix37's Avatar
JL Audio recommends 18inch (W) x 11 inc (H) x 9 Inch (Depth) if that matters.
Thanks guys
Old Nov 22, 2010 | 02:16 AM
It'll be fine, it'll look stupid in the trunk and take up a lot of room, but sound-wise it should be ok.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
MrIP35
Nov 8, 2015 10:47 AM
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
