What are your guys opinions on BEST Double Din
Old Nov 28, 2010 | 06:02 PM
  #31
Wrathernaut's Avatar
Gentle Manne of Leisure
Nope, I find the visibility just fine out the rear window, so I can't really give an informed opinion on the cameras.
I wouldn't mind the expensive Pioneer one that does the parking distance marker lines and corrects for camera location and such though.
Old Nov 29, 2010 | 10:42 PM
  #32
bryantp757's Avatar
I just put in a pioneer avic 920bt,,,,love it...I can stream my pandora from my phone automatically through bluetooth. The way the file structure for mp3s are...makes it super easy to find your song. The small miniSD slot can store 16gb worth of music!! REAR USB WIRE CONNECT is another option for the thumb drive. I got it for 600 off ebay instead of 999 from Best Buy. I still have to repin my parking break wire. Ive had an eclipse unit and kenwood...and so far Im pretty "wowed". I wish you were in the 757 so I could let you see how great it is.
Old Nov 29, 2010 | 11:21 PM
  #33
eggyhustles's Avatar
Can you stream music on the iphone directly over the bluetooth or just pandora?
Old Nov 30, 2010 | 02:43 AM
  #34
File structure is fine if you're doing a small amount, but doesn't work when you've got several hundred artists and a thousand albums to get through.
Yes, you can stream regular audio over bluetooth.
Old Dec 2, 2010 | 03:00 AM
  #35
gl35's Avatar
I have a few quick questions...
1. Where to mount the GPS antenna from my new AVIC x920bt? I was thinking right above the clock maybe, facing the window, out of site, still able to see the satellites.
2. I received my new Pioneer deck today, looking at it I noticed it has a speedometer wire, where might I find this wire to tap into?
3. where is the parking break wire to tap into for the parking break wire coming out of the head unit?
4. Is the USB and AUX out ONLY for Ipod, or can I connect my Android phone to it?
Oh, BTW I bought a back up camera, if anyone is interested this is what I bought.
Amazon Amazon
thanks -
Old Dec 2, 2010 | 05:43 AM
  #36
1) I attach mine towards the top of the metal arm that screws in just below the clock. This acts as the metal required beneath it, and there's nothing metal above it. I have done this in all my installs of GPS headunits in G35s and have no reception problems. I can't reach my pictures while at work, but if you search, you'll find the pictures of this in several of my posts.
(Edit to reverse color/stripe) 2) White with green stripe on the harness that contains the wires that get connected to the steering wheel remote adapter.
3) I just did the bypass so that I wouldn't have to worry about the parking brake wire, and so my passengers could input destinations while I drive.
4) The rear AUX inputs are RCAs, and will take whatever input you want, you'll have to set them up in the audio settings to be iPod mode or simple AUX inputs. The front will take whatever via the 3.5mm input. The USB port will work with a thumb drive, phone or anything else that store music in MP3s. If it is stored in some strange sync'd database that you can't find by browsing the folders, you can't. You won't get the voice recognition that the unit supports with the iPod either.
Old Dec 2, 2010 | 06:15 AM
  #37
im bout to get rid of my w900 for this
This unit is
The netflix and youtube streaming has sold me
Old Dec 2, 2010 | 06:44 AM
  #38
The thing I like best about these units is they have definitely raised the bar (in everything but their navigation, which is still just fine, just not as good as others) for what the next generation will have, and I'm glad that Pioneer stuck with the advanced voice recognition for iPod/iPhone music searches.
Old Dec 2, 2010 | 07:24 AM
  #39
Agreed..the nav does suck on the pioneer units. Good thing is, most of us have smart phones that can do the job.
Old Dec 2, 2010 | 08:12 AM
  #40
OBsessed's Avatar
Originally Posted by Wrathernaut
1)
2) Green with white stripe on the harness that contains the wires that get connected to the steering wheel remote adapter.
This is interesting, I would have thought that your speed was calculated through the GPS like it is on a standalone unit (TomTom for instance). I always liked having a backup check on my speed from another source (to correct for different size tires/wheels, for example). Do all of the GPS head units connect like that or are any of them using GPS to measure speed?
Old Dec 2, 2010 | 08:23 AM
  #41
I wouldn't call it "suck", but compared to some that do redlight cameras, custom voices, and other things, it's not as good. Re-routing is fast, and the voice recognition for POIs is pretty good too.
Sony's got some great looking nav on that tom-tom one, but the rest of the unit is so horible I could never use it.
Old Dec 2, 2010 | 08:24 AM
  #42
It does calculate through the GPS. The speed wire is so that it can tell speed when in a tunnel where GPS fix is impossible, or when it's cutting in and out when in a city with tall buildings.
It doesn't require it, but very recommended.
Old Dec 2, 2010 | 08:27 AM
  #43
OBsessed's Avatar
Ok, that makes sense, and is good to know. Thanks man!
Old Dec 2, 2010 | 11:36 AM
  #44
gl35's Avatar
Wrathernaut, when you say
Do you mean this is part of what I wire up to the PAC SWI-PS?
Thanks.
Old Dec 2, 2010 | 12:24 PM
  #45
No.
There's a harness that's part of the car that you get the green and red wires that get wired to the PAC SWI. If you don't have nav, and my memory serves well, there's only 4 wires on it. Red (wired to SWI), Green (wired to SWI), Yellow (grounded when using SWI), and white w/green stripe (VSS).
Last edited by Wrathernaut; Dec 4, 2010 at 05:42 PM. Reason: D'oh - it's white w/green stripe, not the other way around.
