What are your guys opinions on BEST Double Din
Old Dec 2, 2010 | 01:24 PM
  #46
gl35's Avatar
Ok...
Where is the this wire harness, under the steering wheel column?
Or behind the radio?
thank you again, you have been really cool about this.
Old Dec 2, 2010 | 02:29 PM
  #47
Wrathernaut's Avatar
Gentle Manne of Leisure
Behind the stereo.
Old Dec 2, 2010 | 06:38 PM
  #48
bryantp757's Avatar
Make sure you dont order a pac swi-x.... I should have ordered the pac swi-ps!! I took everything apart just to figure this out ...another 40 bucks! Still its worth it doing it myself!
Old Dec 2, 2010 | 07:31 PM
  #49
bryantp757's Avatar
I dont think you will have a problem using your iphone to stream over bluetooth. If my droid x will do it...I dont see any reason why it wouldnt. I remember when I had an iphone and I had bluetooth headphones for the gym. They probably work the same way. The only negative is that it doesnt stream your music info ...just the music. Im using a 920bt and my firmware version is 2.0000. I need to upgrade it by sd to 2.3. The firmware upgrade actually has pandora icon to your modes fm am pandora etc.
Old Dec 2, 2010 | 10:04 PM
  #50
gl35's Avatar
I already ordered the PAC SWI-PS, should be here Saturday.
Old Dec 5, 2010 | 01:31 AM
  #51
gl35's Avatar
wrathernaut! I can't find the purple (I think) wire to turn the reverse on, or should I say the one to hook up to the purple wire coming out of the back of the pioneer deck for the rear view camera to turn on.
Also, just to be sure, I need to be sure, the white/green wire is for the speedometer wire coming off of the x920bt? Right?
Old Dec 5, 2010 | 02:42 PM
  #52
Yep, the white/green is vehicle speed sensor wire.
You might have to run that reverse trigger wire all the way to the reverse lights, I've never done a backup camera in these cars, but I know that's a guaranteed spot to connect the reverse wire.
Old Dec 5, 2010 | 03:05 PM
  #53
gl35's Avatar
I slaved over the G, all afternoon and into the night. It is installed, except for the rear view camera.
One question, is the Nav always in 2D, or can I make it 3D? It looks so 1990's in 2D
Old Dec 5, 2010 | 03:35 PM
  #54
Yeah, it will switch.
Old Dec 9, 2010 | 07:18 PM
  #55
impulse_x's Avatar
Thanks guys.. I was looking for info on this too..
Old Jan 4, 2011 | 10:10 PM
  #56
blAk mAx's Avatar
anyone running the ebay DD from japan/china ?
Old Jan 5, 2011 | 01:14 AM
  #57
OBsessed's Avatar
Pretty sure most car electronics are made in japan or china, got a link?
Old Jan 5, 2011 | 02:43 AM
  #58
blAk mAx's Avatar
http://cgi.ebay.com/hd-digital-lcd-double-din-car-dvd-player-tv-FREE-CAMERA-/170585749358?pt=LH_DefaultDomain_0&hash=item27b7b3f76e
http://cgi.ebay.com/7-DVD-GPS-NAVIGATION-2-DIN-CAR-RADIO-DVD-PLAYER-CAMERA-/190485981997?pt=LH_DefaultDomain_0&hash=item2c59d96b2d
http://cgi.ebay.com/7-LCD-Car-DVD-Player-GPS-NAVIGATION-Stereo-Radio-Camera-/190485982025?pt=LH_DefaultDomain_0&hash=item2c59d96b49
http://cgi.ebay.com/ebaymotors/7-Dou...fAudioQ5fVideo
Old Feb 13, 2011 | 03:46 AM
  #59
MikeGrote's Avatar
If I get the dd adapter with the dual climate control, is there a single din adapter I can put in there with a panel covering the remaining space? I was hoping to mount gauges in the paneled area, thanks
Old Feb 13, 2011 | 08:45 AM
  #60
Something like this would probably do it for you:
Amazon Amazon
