Ipod Intergration Kit?
Old Nov 22, 2010 | 08:00 PM
ayrayray09's Avatar
best Ipod Intergration Kit for my 06 sedan bose hu ?
any comments would be nice thanks
Old Nov 22, 2010 | 08:06 PM
DrewLe's Avatar
I have the same question also.
OP, you could purchase and install the factory integration kit, but thats 150+.
Sub'd to know what other results there are.
Old Nov 22, 2010 | 08:27 PM
Deepdiver's Avatar
USA-spec
https://g35driver.com/forums/audio-v...-pa15-nis.html
Old Nov 23, 2010 | 02:51 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Yeah, USA SPEC's fine.
Whenever this question comes up though, with the high failure rate of the stock stereos, does it make sense to drop $150 into a minor upgrade?
Save up and get the truly best iPod integration you'll ever get in the car - an aftermarket headunit. You'll need one soon enough anyway.
Old Nov 23, 2010 | 01:13 PM
Deepdiver's Avatar
shop around and you can pick up the kit for $120. If the stereo does go out you can at least sell it for half that...so really you're only out only $60 and 30-45 minutes of your time for install.
Old Dec 17, 2010 | 11:07 PM
DRKNYT's Avatar
i have a quick question. I'd like to know which one to get before I go ahead and order. I have an 05 coupe that's non-Bose and doesn't have the SAT button and is not XM ready. Is there a different cable that I need in order to get my ipod/iphone hooked up, or does the USA Spec Pa15-NIS work fine with my unit?
Old Dec 19, 2010 | 08:38 PM
AlexNY's Avatar
use spec nis will work fine. it connects directly to ur factory radio.
Old Dec 19, 2010 | 08:56 PM
DRKNYT's Avatar
Ok, so I don't need to have the SAT or CAT or whatever those buttons are in order for it to work? It connects to the factory radio in the front or through the back? Thanks again for your response. Also, aren't there two different versions? The 11 and the 15 or something like that?
Old Dec 24, 2010 | 06:06 PM
DRKNYT's Avatar
This is the setup I have...no Bose, no SAT button. Which one would I need?
Old Dec 24, 2010 | 07:37 PM
AlexNY's Avatar
just get the pa15-nis, it connects to the back of ur factory radio
Old Dec 24, 2010 | 08:06 PM
DRKNYT's Avatar
Ok thanks, just didn't want to get the wrong one, install it, then having to take it out and replace it. Thanks again.
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Extreme Dimensions
Exterior-Vendor
Oct 29, 2015 10:24 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
