Power Inverter for PS2
You guys with PS2s, what's the wattage of your power inverters and did you hardwire it? If so, where? Thanks
Eric
Black 5AT Coupe, Navi, Falken Koblenz 19", HKS Legamax Exhaust, ZTube/Stillen, Grounding Kit, RSR Springs, Tokico DSpec Shocks
Eric
Re: Power Inverter for PS2
I was having some issues with this last month. Sony lists the wattage of the PS2 as 79watts. I had a 200watt inverter (cheap one i got at Kmart) and it kept shutting down b/c of over-wattage.
I was told by a few people that most inverters put out less than half of what they're rated for under normal conditions in the car. I switched to a 400watt inverter (and put it in the trunk b/c it has little cooling fans that were noisy as hell) and now have no problems.
Just this week i switched to the newer PS2 (much smaller and less wattage) and now the 400w inverter is overkill but mine also has a second outlet to plug other stuff in too.
