Navi into video DVD player
Old Oct 26, 2004 | 04:24 PM
GoNAbESIKWEnIMDn's Avatar
well im new to this site and its really nice but i have one question i geting a new 2004 6MT with Navigation and i was just wondering if there is a way to turn the stock screen into a DVD player. any info would be great
i love anything with a motor most of all the G35 Coupe
Old Oct 26, 2004 | 05:54 PM
FrankieBallzzz's Avatar
Re: Navi into video DVD player
i strongly advise you to be prepared for the upcoming onslaught!
Old Oct 26, 2004 | 06:09 PM
god_of_cpu's Avatar
StreetDeck.com Developer
https://g35driver.com/forums/showfla...view=&sb=&vc=1
<a href ="http://digitalwheelz.com"></a><P ID="edit"><FONT class="small"><EM>Edited by god_of_cpu on 10/26/04 03:09 PM.</EM></FONT></P>
Old Oct 26, 2004 | 08:35 PM
where can i get the AvElectronics unit? i think that is the one i would like to get and how bad is the sound?
Old Oct 26, 2004 | 09:14 PM
ikSardarG's Avatar
This is my reply to a post which someone else suggested... You just needed to use the search feature on the board:
Re: "Can I mod my NAV to play DVDs???" [re: kpierson]
ikSardarG (enthusiast )
10/09/04 04:59 PM
Here it is:
1.) The answer is YES. You can mod your your factory Navigation screen to view other video sources, and switch back to the factory guidance display even while there is video playing in the background.
2.) You cannot utilize the factory DVD-Rom in the glovebox to play Video DVDs. This unit is made to read the Navigation data only, and it would take entirely too much time and research to reverse engineer this unit. You must provide your own video sources. This has been confirmed.
3.) There are a few choices on the market available to allow you to 'switch' to an external video source. The first and most popular unit is the AV Electronics unit. This unit has a few key features, mainly 3 external video/audio inputs, optional S-Video input, multiple screen outputs, FM Modulation for sound and an RF Frequency remote control. It also allows you to have different video sources playing on different monitors in your car (if you have them). A reverse camera can also be connected optionally, under VID 3. If used, the AV Electronic unit will automatically switch to VID 3 and display the video source from the optional back-up camera when the vehicle is in Reverse gear.
The second unit drawing some attention on the forums is manufactured by Pac-Audio Accessories and is just now coming to the market this month. This unit is a single video input switcher only, and will allow you to connect one video source to your navigation screen. The unit does not provide any options for audio at this time, but most others would recommend purchasing the PAC AAI-NIS unit to utilize the factory headunit's SAT button for an 'aux' audio source. Of course, most users can expand on the number of video inputs by simply installing a video splitter or switch (like those from Radio Shack for video systems).
4.) The Video quality from both units is good. It is not HDTV like picture quality, however is great considering the screen which is being utilized. The Fm Modulated sound from the AV Electronic box is fair, and can easily be improved upon. Some users have forfeited the built-in sound modulation and have instead installed tape adapters or purchased the PAC AAI-NIS unit. The improvement is remarkable, even just from the tape adapter.
5.) The costs of the video switcher units available on the market have been noted anywhere from $200.00 to $500.00. The prices are dependant on the brand of the unit and the features included.
6.) Both units discussed above can be installed by a novice DIYer. The installations are easier to accomplish, once you understand how the vehicle's interior is assembled. The best way to understand the assembly/disassembly of the dash are is to read the Double-Din installation guide posted by Doctron1. This is one of the best write-ups on the subject and it provides some key hints and tips (along with pictures) to help you better understand the areas which must be accessed to successfully install both the PAC units and the AV Electronic boxes.
- The wire harness to install both the AV Electronic unit and the PAC Video unit are located behind the glovebox area. Most installations will require the lowering of the glovebox, removal of the center console area and removal of certain other trim pieces to allow access behind the factory headunit. If you do install the PAC AAI-NIS unit as well, it requires to be plugged in to the back of the factory headunit.
7.) The units DO require the cutting of wires for installation:
- AV Electronics unit requires the cutting of (1) wire and a source of 12v power. The AV Electronic unit can be ordered as G35 specific, making installation simple. Most installers have spliced the 12v+ power from behind the factory headunit, but this is optional.
- PAC Video Switcher requires the cutting of 4-5 wires depending on the vehicle, plus requires 12v+ power as well (for most vehicles). The PAC unit is NOT G35 specific, but is rather universal.
8.) If you are not comfortable enough to install your own units, the installation prices would vary depending on your local car audio shop. Any experienced installer would be able to do the installations without issue. As a dealer for these units, I have heard install prices from customers ranging from $100 to $250.00 and more. I personally always suggest a DIY install to help save on the costs of the system. It also gives a great sense of pride as well.
9.) You can get more information on the AV Electronic unit at www.avelectronic.com, or for information on the PAC unit, please visit www.pac-audio.com. You can also PM me here as well for more information.
Hope this helps.
ikSardarG
I can help you out if you need more info on ordering a unit.
**** Official PAC Aux Input Dealer!!! ****
SWI-X units available also!
Navi-Conversion Kits at Discounted Pricing
*Authorized AV Electronic Dealer*
Old Oct 27, 2004 | 07:43 PM
g35mt's Avatar
frankie,
hehehhehe....that was funny. it wasn't that bad as i expected.
g35mt
Old Jun 28, 2005 | 06:16 PM
tvandnav2go's Avatar
Hi Everyone
The G35 mod involves that you cut 4 wires and splice in. There is no plug and play for this car because it does not use standard nissian, infinity connectors.
The mod has 2 inputs 1 for DVD and 1 for backup camera. The unit auto switches to backup camera when you put the car in reverse. Yes the Mod works on the 05 G35 and 06 M35. The RGB mod is $200. If you want to check out our service and quality you can go to
http://www.acurazine.com/forums/showthread.php?t=306979
one of the many forums we do group buys on. You will see that we have sold over 100 mods alone on this forum with 100% customer satisfaction.
We have RGB units for every model car and we provide the best RGB units at the best prices around. We will NEVER be undersold. We also offer many plug and play solution. Feel free to call us at 718-763-7367.
Thanks Dominic of www.TVandNav2Go.com
Originally Posted by g35mt
frankie,
g35mt
Old Jun 28, 2005 | 06:36 PM
BlackonBlackG35's Avatar
There is no need to post your advertisement 10 times in a row.....
Old Jun 28, 2005 | 07:45 PM
g8tor20's Avatar
FGC's official flip flopper
LOL. He resurrected every damn NAvi DVD thread!! hahahaha
Old Jun 28, 2005 | 09:08 PM
Blackjack's Avatar
ROTFLMAO! Go easy on him guys.
Old Jun 29, 2005 | 05:11 AM
nbp78415's Avatar
i think he even trolls and uses other names to get the navi question brought up. SoOOOO MANY NAVI THREADS NOW!
Marlin84
Apr 1, 2020 12:52 PM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Video Share
Sep 28, 2015 06:29 PM
