Radio Problems
Old Dec 16, 2010 | 01:22 PM
ShaneH85's Avatar
Radio Problems
For some reason on my 04 coupe when i switch to listen to the cd player or the sat radio only music comes out of my passenger side speakers? But when its on radio all of them work correctly, now my sat has been changed to use the ipod so im not sure if thats the problem or what, but this is the most annoying thing to me because i can clearly hear all the music in my right ear!! any suggestions?!?
Old Dec 16, 2010 | 02:47 PM
TannerG's Avatar
IDK if it would affect the sat input issue, but look at this thread:
https://g35driver.com/forums/audio-v...g-channel.html
Old Dec 16, 2010 | 03:36 PM
ShaneH85's Avatar
thanks man ill try this, i just wonder when you cut the ribbon down how do you strip the ends to show the connectors?
Old Dec 16, 2010 | 04:49 PM
TannerG's Avatar
You aren't cutting the whole connector off the cable, only about 2-3 mm from both ends. That way a new part of the connector is being used.
I would definitely try cleaning the connectors before cutting them. I believe that's mentioned in the same thread. You can use a contact cleaner. I wonder if a bit of brass polish would help...
Test it before you put the whole dash back together.
Old Dec 17, 2010 | 04:02 PM
ShaneH85's Avatar
ok yea i found a thread on here on how to remove the radio so im going to take sometime this weekend to do it. thank god my dads owns a hvac company so i now have heat and ac in my garage!
Freeman186
Sep 6, 2023 10:07 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
Jnm07
Sep 5, 2015 01:16 AM
kevintandmd
Sep 3, 2015 06:41 PM
