ho alternators
Old Jan 13, 2011 | 06:18 PM
eggyhustles's Avatar
Originally Posted by pythonjosh
FYI, DC doesn't have Infiniti or Nissan in their drop down menu for makes.
They can custom make one.
Old Jan 14, 2011 | 03:55 AM
The Stimulation's Avatar
Originally Posted by kennymo
this is the only one i can find without having one made
http://www.qualitypowerauto.com/catalog.php?item=197
I got my 170A HO alt for my Accord from them. Also bought an Odyssey PC1200 and PC2150 from them. I'd say they're reputable.
I'm running a JBL GTO 1201.1. Haven't done the big 3, but I have a red top up front and yellow in the trunk. Not my top choice but can't complain for 170 shipped total for both. Lowest it drops is 13.8V. No dimming or anything either. An upgraded battery would help out a ton. I'd do that before buying an HO alt. Go with the cheapest first.
Old Jan 17, 2011 | 08:27 AM
grovefromnh's Avatar
What is the output from the stock alt.?
Old Jan 17, 2011 | 10:44 AM
pythonjosh's Avatar
I think it's 120amps. 120 is really good compared to other cars. Even enough to support a good system (with a good gel battery).
When you get to needing a second battery/capacitor in the back, with 2+ amplifiers, then you may want to look into a HO alternator.
Basically you will need a better alternator whenever your current alternator is spending more amps on running everything in the car than to charge the battery (the battery just takes whatever leftover amps it needs to recharge).
The electrical information should be available to find out how many amps your head unit, amplifiers, speakers, crossovers, draw (amps).
Add it all up and that tells you how many amps are left over to charge the battery(ies).
Old Feb 20, 2011 | 10:43 AM
g35man04's Avatar
CLUB MODERATOR
I Will bring this to life again...I have been doing alot of researching....I currently have a capacitor installed/Optima Red Top on the car....however I do have alot of Lighting Mods on the car and JL audio e2150, Full components, Head-unit, 2 JL Audio w3v2 and 500/1 when I turn up past volume 20 on the car I have serious dimming problems including headlights pulsing.
Currently I do not have a grouding kit installed anymore but I will be switching and installing that again just need to be able to wire-tuck the grounding kit so its hidden.
i have been reading though and our current alternator is a 110 Amp alternator. I have seen that the 04 Nissan Pathfinder's alternator is direct replacement to our current cars and is a 220amp alternator! you can get them off ebay for about 250 shipped new with warranty. I think I am going to take this route next after I install a grounding kit on my car to see if that corrects alot of my problems. my optima red top is plenty of power to run all of this but need to fix the dimming issues so I dont get pulled over at night.
The crazy thing is lastnight I did some testing with a battery charger on my car....I started the car and turned the volume up to about 20-22 so that I could get the lights to pulse. I took the battery charger and plug it up to my battery and cranked it over to 225 on the battery charger...sure enough lights pretty much stopped dimming at that output. As soon as I pulled the charger off immediately the lights went back to pulsing. I think this basically showed that my alternator wasnt able to product enough current to run everything on my car. Any input would be greatly appreciative.
Pathfinger alternator
http://cgi.ebay.com/ebaymotors/220A-...Q5fAccessories
Thanks
Old Feb 20, 2011 | 10:49 AM
g35man04's Avatar
CLUB MODERATOR
also found this today from dcpower.
https://www.dcpowerinc.com/11051-270-xp.html
Old Feb 20, 2011 | 11:48 AM
Def get the pathfinder alt
Upgrade your batt too..optima's are garbage.
Old Feb 20, 2011 | 12:10 PM
g35man04's Avatar
CLUB MODERATOR
okay will do! so upgrade to the XS battery?
Old Feb 20, 2011 | 12:15 PM
Xs or stinger
Go for the biggest one u can fit under the hood
Old Feb 20, 2011 | 07:15 PM
I'll checkout my NISSAN dealer on Tues as they might be busy on Mon. As I bought my G35 and my 2011 Frontier 4x4 from them I think I'll get a discount.
Old Mar 3, 2011 | 07:14 PM
The specs for an 04 Pathfinder say the alt. is 110 amps like ours. NO 220 amps.
Old Mar 3, 2011 | 10:51 PM
g35man04's Avatar
CLUB MODERATOR
hhm.....well I ordered this one already. Will be here saturday or Monday.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Old Mar 3, 2011 | 11:30 PM
LiquidClen's Avatar
Keep us updated!!!!! I will probably be buying one too if it works!
Old Mar 13, 2011 | 04:50 PM
PEARL-G's Avatar
any updates
Old Aug 7, 2011 | 02:32 PM
  #30
PEARL-G's Avatar
bump
