Need advice, what should I do????
Old Jan 14, 2011 | 07:37 AM
kgh31386's Avatar
I have an 05 G sedan with BOSE, and the quality is ok with me I suppose..but the system has me scared believe it or not. The temp has dropped into the teens and I made another thread about what it does on the first start in the cold(loud popping/feedback) until the heater starts blowing some warm air. Anyway I'm taking it to Infiniti next week for them to see. BUT..here's my dilemma.
I have a Pioneer P3100(just like the 3200 basically) sitting in my room, I have 2 Boston Acoustic 8in subs in my room that I pulled from my old car, and a"Infinity Reference Series" amp. The problem is I think it's only a mono channel amp. But the pioneer HU has a built in Amp. What do you guys think I should do? I plan on swapping out my HU for sure as soon as I order the JDM kit. But I also thought about getting rid of the Bose Amp too. Here are the specs on the Infinity amp I have, so I'm wondering if the Bose speakers will be ok with the Infinity amp. Do you think? I hear you DONT have to run new wires to the doors if you replace the Bose speakers. But how much are you guys paying for the install when you do the door speakers+HU+amp/sub??
- 761W peak output @ 2 ohms
- 456W RMS (continuous) x 1 @ 4 ohms
- 657W RMS (continuous) x 1 @ 2 ohms
- Full-range preamp outputs facilitate use of multiple amplifiers without the need for noisy and expensive adapters or signal splitters
- Dynamic Bass Optimization (DBO) provides variable filtering with adjustable Q below 100Hz to optimize low-frequency output
-12dB per octave electronic crossover
- Frequency response: 17-302Hz
- Sensitivity: 75mV
Fox843
Nov 7, 2015 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
