my budget build ? ( will this work )
Old Feb 4, 2011 | 08:55 PM
Krispyklene's Avatar
with my g35 04 coupe is equipped with factory bose and navi. is this stuff compatible.
if it isn't... what kind of amp is the cheapest i could get away with using?
http://www.frys.com/product/6166669
http://www.frys.com/product/6192199
http://www.frys.com/product/6192599
OR this as an amp
http://www.frys.com/product/5537250
i'm kinda confused on what amp would be compatible with my factory bose system? please help
Old Feb 4, 2011 | 10:25 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
That box is too small for the sub.
Neither of those amps accept a differential-balanced signal. (What the Bose headunit puts out).
The easiest amp to get your hands on that accepts a differential-balanced signal are JL Audio amps.
Old Feb 4, 2011 | 10:27 PM
kennymo's Avatar
why does the amp have to accept a differential balanced signal? thats definatly not how i did my amp shopping. im just curious so that i can learn. thats all
Old Feb 5, 2011 | 03:44 AM
hmmm anyway i can get away with gettin' somethin' from FRY's? i have a hookup there... so that would be awesome to get somethin' through them. i don't believe they carry JL... and aside from that... JL is usually expensive. unless i go on ebay or CL is it a 1 channel i should be looking for or...?
Old Feb 5, 2011 | 10:53 AM
eggyhustles's Avatar
how much is your discount?
Old Feb 5, 2011 | 10:57 AM
Because the bose headunit outputs a differential-balanced signal.
http://www.bcae1.com/ballndrv.htm
http://en.wikipedia.org/wiki/Balanced_audio
Shortest explanation that's understandable - an amp expecting a balanced signal that gets an unbalanced signal sees half of the audio signal as noise, particularly along the lower frequencies (bass) and makes the audio both quiet and degraded.
With the budget you seem to have, I can't recommend you installing anything at this point. Keep saving.
Old Feb 5, 2011 | 11:38 AM
wow... well the sub is 50 bucks... maybe i should just pick up the sub? and find a used JL amp... ?
Old Feb 5, 2011 | 11:55 AM
Dont buy that sub
Get this
http://www.sonicelectronix.com/item_...-MM840DVC.html
50 dollars cheaper than the one @ fry's
Old Feb 5, 2011 | 09:49 PM
well the one that i showed is actually 50 bucks... so it's 30 bucks cheaper than the polk audio... but i don't understand how i have to run a JL amp... tons of people are running other amps on this board... is it because they don't have bose or what?
Old Feb 5, 2011 | 10:05 PM
zoop425's Avatar
you dont have to use JL. You can use which ever one you want.. I would recommend a Class D amp if your just using it for a sub. All you have to do then is find your bose harness, tap the front left and right speakers (+ and -) prior to entering the stock amp. Those will go into a LOC (line out converter/ high-low) which convert the stock signal to RCA (right and left balanced output) which go into the amp and badabing badaboom..
Old Feb 5, 2011 | 10:10 PM
B_Lam's Avatar
Just save up money and buy a better sound system. All that stuff you plan to buy from fry's is going to be worthless. Probably won't even sound good or barely make a difference than your stock sounds now.
Old Feb 6, 2011 | 12:28 AM
And badabing you're trying to send a differential-balanced signal to an amp that's not made for it. Good luck with sound quality on that. LOC isn't a balanced signal converter.
You don't have to use JL Audio, there's a few others that take differential-balanced signals, but all JL Audio amps do.
Old Feb 6, 2011 | 05:17 AM
ok thanks y'all. im gunna shop for a used jl amp
Srinidhi
Aug 7, 2015 03:38 PM
Frostbite91
Aug 2, 2015 04:59 PM
paniaguag35
Jul 29, 2015 12:05 PM
mushu
Jul 15, 2015 03:55 PM
