Would this amp suffice/ work in g35 sedan bose
Old Feb 13, 2011 | 10:00 PM
boostedforlife's Avatar
Hi,
I got this amp for free from a prelude that I parted out a little while back, i know the system that was in the lude was clean, but it did use one other amp than this.
Amp is: Toshiba tp-873
I wanted to know if this amp can either
1) be used to increase volume /sound quality of current door speakers
2) be used to make the sub louder/ improve the sound quality/
3) can it do both or just one or the other? if only one which one would you use it for?
I dont need anything to be show/ compeition status, i just figure since it was free if it would give me any benefit?
I plan to put a better sub in stock location, possibly.
Current set up
polk db 650 in rear doors
Polk Audio db6501 2-Way 6.5" Components in front w tweets
stock 05 bose nav
thanks!
Attached Thumbnails Would this amp suffice/ work in g35 sedan bose-img_3519.jpg   Would this amp suffice/ work in g35 sedan bose-img_3520.jpg   Would this amp suffice/ work in g35 sedan bose-img_3521.jpg   Would this amp suffice/ work in g35 sedan bose-img_3522.jpg
Old Feb 14, 2011 | 03:50 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Most of the EQ horribleness in the Bose amp is towards the sub, so you could probably get away with using a LOC on the signal going to the front speakers and use it that way, since the amp won't take the differential-balanced signal directly from the headunit.
Old Feb 15, 2011 | 03:23 AM
So you are saying, I can use this to power my front speakers and the rest would still go off the old amp?
Old Feb 15, 2011 | 01:43 PM
That would be the way I'd recommend doing it, if you decide you just have to do it.
But going with an amp that can take the differential-balanced signal from the Bose headunit (JL audio are easy to find and do it well) and getting rid of the Bose amp completely is a much better option.
Old Feb 16, 2011 | 03:55 AM
ahhh gotcha, I thinkyour right im better of actually buying a new amp, do you have an recommendations for cheap, and mid prices ones?
Old Feb 16, 2011 | 01:54 PM
Well, if you keep the Bose headunit (I don't recommend you do) then you need one that can take differential-balanced signals. As I said, JL is the easiest to get your hands on that will.
This amp plus an amp wiring kit would be as close to a plug & play replacement:
http://www.woofersetc.com/p-7216-g66...amplifier.aspx
Thunderaan
Jul 22, 2015 07:40 PM
vstypicals
Jul 20, 2015 10:55 PM
Ninjay16
Jul 20, 2015 01:21 AM
