Problem with trim when installing Pioneer Avic x920bt.. Please help!
Old Mar 4, 2011 | 01:58 PM
josh.irvine.6's Avatar
Hey guys, I was in the process of installing my JDM Trim Kit and Pioneer x920bt and came to a problem when the headunit was installed. The gap around the headunit can't be fixed by a universal trim piece.. What did you guys do to have a clean install and to make it work?? Any suggestions or pics guys would be great.... Kind of in a jam... They are suggesting I order the metra kit, but... I'd rather not...
Old Mar 4, 2011 | 03:02 PM
zoop425's Avatar
most people make one or get one made. go to an audio shop and they should be able to make u one out of thin mdf or plastic wrapped in vinyl
Old Mar 4, 2011 | 03:07 PM
agedog2gt's Avatar
I would assume something custom? Or do you not want to go that route?
Old Mar 4, 2011 | 04:38 PM
OBsessed's Avatar
Had the same problem with my Z120, didn't quite fit through the opening inside the little Scoshe trim ring and the trim ring itself was a little too wide to fit inside the JDM trim plate. A little trimming here and there and it worked, then I got carried away and trimmed too much, then I just got a sheet of black ABS plastic ($12, give or take) and started hacking away again. Worked out fine but no pics available at the moment can't find my camera, sorry
Old Mar 4, 2011 | 04:42 PM
G35Papa's Avatar
I had to trim down the kit my AVIC came with in order to fill in the gaps around it.
chinee
Jun 10, 2024 07:48 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
hdmark
Apr 29, 2019 04:31 PM
attarday
Jul 15, 2015 04:03 PM
