Easiest place to run 4 gauge power wire through firewall?
Old Mar 10, 2011 | 06:58 PM
tibasnatch's Avatar
did a search found a couple threads but no pics and couldnt find where they were talking about.....I look and I can see a large hole where u can see i think the cabin air filter....
pics or exact location would be great. thanks
Old Mar 10, 2011 | 07:25 PM
zoop425's Avatar
There is a big grommet right behind the battery and a smaller one near the driver side foot well
Old Mar 10, 2011 | 07:34 PM
tibasnatch's Avatar
do I need to remove the battery itself? I took off the main battery cover...with those pins....do I need to take off any more plastic pieces?
Old Mar 10, 2011 | 09:52 PM
nar93da's Avatar
You'll need to take off the battery cover and the plastic piece that it snaps into. Next you'll remove the passenger side wiper cowl, which is just held in with clips. After removing the wiper cowl you'll see the wire and grommet. Cut a little slit in the grommet and push the wire through. Then your all done.
Old Mar 10, 2011 | 11:52 PM
tibasnatch's Avatar
great, thanks
Danielek
Aug 11, 2015 09:33 AM
ClwMike
Jul 23, 2015 12:55 PM
