Need help from audio DIY guys with G sedans
Old Mar 14, 2011 | 03:49 PM
Black Betty's Avatar
Can anyone tell me accurately the length of power wire needed to run from the OEM battery location to a trunk mounted amplifier in a G sedan? It's not for me (I drive a coupe) and I dont need any system advice, I just need to know the lenght of the wire needed. That's all. Thanks!
Old Mar 14, 2011 | 05:04 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
I was fine with this dual amp kit: http://www.sonicelectronix.com/item_...-AMP1040D.html
That reached along the floor by the doors in the passenger side, under the trim on the passenger side and up to the underside of the rear deck, where I mounted my distribution block. From there the pair of 3 foot lengths of 4 gauge each went to the amplifiers mounted to the back of the rear seats.
20' would probably be enough for a single amp anywhere along the passenger side in the trunk, but if you're trying to mount on the driver's side, you might need a few more feet.
Old Mar 14, 2011 | 05:12 PM
Thank you, that's exactly what I needed to know.
Mry
Mar 3, 2023 01:03 AM
mjfenix
Aug 17, 2017 05:49 AM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
bTanz
Oct 15, 2015 02:31 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
