2005 G35 Sedan use same Bose wiring as 2003?
Old Mar 22, 2011 | 12:26 PM
ghart99999's Avatar
Hi all. Newbie to the G35s here?
Just purchased a used 2005 G35 Sedan. Has the Bose system with no nav and the 7 speaker setup with the sub in the read deck. I am tearing out the system and doing a custom install. I noticed the sticky for the 03 Bose wiring from the amp. Will this be applicable for the 05 as well as it seems that the V35 forums lump the 03-05 models together.
If not, does anyone have access to the wiring for the 05 sedan? Thank you very much.
Gregg
Old Mar 22, 2011 | 01:04 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Are you keeping the stock headunit? It's *highly* discouraged, since they fail at an alarming rate, so that you'd be stuck without any audio source for your new system.
Additionally, the signal from the Bose headunit is a differential-balanced signal, which few amps are built to accommodate, so whatever money you put towards either an amp that takes the signal, or signal converter would have been better spent towards upgrading the headunit.
If you replace the headunit and amp, you've no need for the wiring diagram.
Anyway, you can find the wiring information here:
http://www.psedog.com/cars/fsm/g35/sedan/2005/av.pdf
Old Mar 22, 2011 | 01:37 PM
ghart99999's Avatar
No I am removing everything. I just wanted to use the stock speaker wiring to the doors so I needed the colors from the amp connectors. Thanks for the link. I assume the stock speaker wiring can handle 75 @ 4ohm RMS? What is it 22 gauge?
Old Mar 22, 2011 | 02:08 PM
Not sure on the gauge, but I'm shoving 75w RMS through it daily. The wiring is thicker than the wiring that's on the speakers themselves, so it should be fine.
laksjd84
Feb 28, 2026 01:58 PM
lemmy999
Jul 25, 2015 12:13 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
