DoubleDin Issue
Old Nov 12, 2004 | 10:01 PM
Gordgee's Avatar
Administrator
DoubleDin Issue
I was asked to post this for <font color=red>BrnSkyline </font color=red> who seems to have ? problems posting to this forum:
<font color=blue>I have a problem with my Double Din...
I bought my double din kit from Strictly Z and followed the instructions in the DIY guide. After the install everything seems to work fine, and my new Kenwood screen rocks. The only problem I have is the A/C. I have to set the temp on 60F in order for the A/C to blow cold air (Its freezing). If I just set it up on 61F it blows hot air (Heater). </font color=blue>
Can anyone help <font color=red>BrnSkyline </font color=red> with this issue?
<font color=blue>[i]GroundingGear™ Equipped </font color=blue>
Old Nov 13, 2004 | 02:38 AM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
Re: DoubleDin Issue
again, its either the AC plug was not reconnected correctly or less likely, the temperature sensor wire has been disconnected during dash swap.
i would try to disconnect and then reconnect the AC plug to the AC controller. I dont know how to reconnect the temp sensor wire if fooling around with the plug doesn't work..
hope this helps...
doc
Old Nov 13, 2004 | 12:34 PM
RamboRami's Avatar
G35driver.com Moderator
Re: DoubleDin Issue
interesting, worse comes to worse he'll have to get a new AC controller
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/Z-Tube/double-din
Old Nov 14, 2004 | 01:52 AM
twinsnails's Avatar
Re: DoubleDin Issue
I had the exact same issue when my DD kit was installed. It ended up that a plug was disconnected under the steering column. Call Dave at Sound Xpressions in Phoenix, AZ 602-438-0352 if you have trouble finding it. He is who worked on my car and he is a G35 coupe owner as well!
Mark
Greddy twin turbo kit with FMIC, Injen exhaust, Volk GTC 20's, Tein Type Flex coilovers, EDFC, Unorthodox Racing pulleys, Lightning Audio Storm modular subs, amps and speakers.
Old Nov 14, 2004 | 03:26 AM
etang789's Avatar
Re: DoubleDin Issue
Oh my friend who also have this problem with his stock G35 coupe...i will inform him the connection under the steering wheel
Old Nov 16, 2004 | 03:06 AM
brnSkyline's Avatar
Re: DoubleDin Issue
gents,
I would like to thank you all for the support and feedback.
Will contact Dave at Sound Xpressions today to take his opinion before I start working on the car again.
Old Nov 16, 2004 | 03:02 PM
BaByBoY779's Avatar
Re: DoubleDin Issue
I have the same problem.
https://g35driver.com/forums/showfla...sed&sb=5&part=
Old Dec 10, 2004 | 01:15 PM
BaByBoY779's Avatar
Help...anyone (DOC RON maybe??)
I have not found a solution to the abovementioned AC problems. What does the AC sensor wire look like behind the dash and where is it located specifically. I have checked under the steering column and nothing was disconnected. DOCRON: Thank you in advance for your help.
Old Dec 10, 2004 | 02:21 PM
docron1's Avatar
I've been reading the Infiniti Service Manual about our air conditioners (section ATC).... very interesting!
Ok....this sensor thing never happened to me but I'll tell you what i read about what we're talking about.....
The official name of the thing is called the "in-vehicle sensor" (ATC-107). It is located in/on the driver panel located beneath the steering column. IF you have done the doubleDIN conversion process, the driver panel is the plastic panel you unscrew near the trunk release latch beneath the VDC button at the very beginning. This is the panel that you drop down to gain access to the driver-side center console side panel where one of the 12V cigarette lighter plugs are.
There is a little grill on that driver panel (which I always wondered what it was for curiously enough) located about 3/4 of the way in from from the driver doorside. If you drop the driver panel down, the in-vehicle sensor is attached to the *inside* of that panel.
I can see how the in-vehicle sensor and its wires might get disconnected when you work on the dash disassembly and drop that panel down and let it hang.
So, what I would do is this: (again, this is from what I read in the service manual and not from personal experience)
1. Raise the steering wheel.
2. Remove the screw located below the trunk release latch beneath the VDC button.
3. *gently* Drop down the driver panel.
4. Check the "in-vehicle sensor" and its wire connection.
5. See what happens....
Let me know if this doesn't make sense....sorry I'm at work so I can't take any pictures to illustrate what I'm trying to describe.......
docron1 (aka joepaniolo)
Old Dec 10, 2004 | 08:23 PM
BaByBoY779's Avatar
Thank you DOC. Before I attempt to correct the AC sensor using your directions, would you be able to email or fax the pertinent pages out of the Infiniti Service Manual? This would help me out tremendously. Please let me know.
Dave
Southern California
Old Dec 10, 2004 | 09:17 PM
docron1's Avatar
Dave,
I PM'ed you
doc
Old Dec 11, 2004 | 03:07 AM
docron1's Avatar
In-vehicle Sensor And Wire That Might Get Loose When You Drop Down Driver Panel
Attached Thumbnails DoubleDin Issue-vehicle-sensor.jpg   DoubleDin Issue-invehiclewire.jpg
G35Rican
Jul 31, 2024 01:37 AM
yosip1115
Sep 9, 2015 03:30 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
