Need Help with AC/Radio for 2005 coupe
Old Apr 18, 2011 | 11:26 AM
hpric's Avatar
Ok my car came with factory Nav which I got rid of when I installed my carpc. I've recently decided to go back to stock (non nav set up) and when I reconnected a factory radio from another 05 coupe nothing seems to work. The radio does not light up and my AC stays on (no control). I have checked my fuses and they are fine, I have tried another radio from another 05 coupe and still get the same results. When I connect the cd ribbon I can here the cd changer shifting but nothing happens, Factory amp is wired in and radio fuse is fine. Any ideas?
Old Apr 18, 2011 | 11:31 AM
iamericgee's Avatar
lol i have the same problem i cant figure it out either it does it once in awhile and just started happening to me a week ago
Old Apr 18, 2011 | 12:14 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Sounds like the classic fried radio/circuit board problem. Considering how common they fail, I wouldn't doubt that you just had two bad ones back-to-back, or if you were using the same circuit board/face for both, that's your problem right there.
Old Apr 18, 2011 | 01:17 PM
hpric's Avatar
nope two completly different radios and board/face
Old Apr 18, 2011 | 06:59 PM
With the high failure rate, I certainly wouldn't discount them both being failed.
Old Apr 18, 2011 | 11:31 PM
The-Dream's Avatar
This happened to me when I took my car apart to wrap it in carbon fiber. I flipped the ribbon that goes into the stock head-unit and it worked again. Not sure what's the science behind it but it worked for me.
Old Apr 19, 2011 | 09:49 AM
hpric's Avatar
Yea I tried that but nothing
mike730
Jan 12, 2018 04:25 PM
trulegend
Audio/Video/Electronics
Jul 31, 2015 03:37 PM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
Blakelyg35
Jul 21, 2015 12:49 PM
