Amp or Speakers blown????
Old May 4, 2011 | 08:37 AM
blk35's Avatar
I have a JL 300/4 and 6.5 components also JL. Everything was playing well until i hit a bump then I started getting distorting out of the fron speakers, looked at the amp and the ohm light flashes. Change the rca's still the same took the door off looked and the speakers connection good. So I wanted to know is the amp bad on those two channels since the rears play fine or is it the front speakers?? Thanks in advanced.
Old May 4, 2011 | 11:04 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Sounds like a speaker wire got loose and is grounding.
Check all your speaker wires for continuity between them and the vehicle body, the one with a good connection to the vehicle body needs to be fixed.
Old May 4, 2011 | 03:13 PM
blk35's Avatar
ok ill look in the other door and see, if the wire possibly has come loose.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
JustinMKN1
Sep 18, 2015 03:40 PM
