Newbie question - Installing an inverter
Old May 27, 2011 | 02:28 PM
ExcelMN's Avatar
I've tried searching and only gotten three kinds of hits - threads that assume a high level of practical knowledge, threads that discuss what is running off the inverter, and threads that have nothing to do with it
I've got a 2005 5AT coupe and Im going to be pulling my head unit out next weekend to install a PA15-NIS. While Im in there I wanted to install an inverter so I could have power available with the ignition off to charge cellular/laptop if needed.
I guess i'm primarilly wondering where to fit the body of the inverter (its 8.5 by 2 by 3 inches). Ive read there is a lot of space under the HU, behind the ashtray and I'm hoping someone can give me a best guess on if this is going to fit and/or have enough airflow.
If it does i'm going to run a USB line out from there past the shifter into the armrest console, and hopefully run a 120VAC cable into the top glove box so I can charge a laptop if needed.
Also, where is a good place to hide a circuit breaker? Should I try and put it in the engine bay, or sneak it somewhere in the cabin?
Old May 29, 2011 | 04:27 PM
sssmasss's Avatar
i think u should but the inverter where you can easily access it.
put it in the trunk of your car.
jsimonk
Dec 22, 2023 03:49 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
