Help with Docking Station
Old Dec 3, 2004 | 02:30 PM
gmen's Avatar
Lightbulb Help with Docking Station
My Del 600m docking station does not seem to work with my inverter. I tried two different inverters. Both work when I plug them directly into the laptop but when I try to use the docking station the computer said there is not enough power supplied to the station. Any help?
Thanks,
Old Dec 3, 2004 | 09:34 PM
dave's Avatar
How much power can your Inverter supply? According to the Dell website, both the Laptop and the Port Replicator use 90 watts of power each.
Old Dec 6, 2004 | 01:09 PM
gmen's Avatar
Docking station, inverter, Carputer
The laptop itself works off my 75 Watt inverter. I tried using a 300 Watt inverter for the docking station and it still does not work. What inverters are others using?
Old Dec 7, 2004 | 06:02 PM
djrobx's Avatar
Stupid question, but have you tried plugging it into a normal, everyday wall socket? Are you sure it works that way? My Latitude docking station knows the difference between different Dell power bricks. If I plug in the brick that came with my laptop, it reduces my laptop to half speed and complains that there isn't enough power. I had to obtain a higher wattage power brick to have it work right.
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
G35xdriver04
Nov 7, 2015 08:31 PM
dcsbh1
Oct 1, 2015 03:15 PM
Cbohannan101
Sep 12, 2015 10:32 PM
