Can't hear music from driverside's speakers
Old Jun 29, 2011 | 09:04 PM
Cooldude04's Avatar
Originally Posted by GR6RR
This is just an early sign of your AC going all whacked out too... Fair warning
Can you please be a little more specific? Will my AC pump out heat instead of cold air? or AC can't be controlled from the controller? .. I'm kinda of worry right now from your warning GR6RR. I only got this car for less than a month...
Old Jun 29, 2011 | 09:06 PM
Cooldude04's Avatar
Originally Posted by willis555
Haha, my name is Sam, Willis is an old nickname.
Anyways, mine did the same thing. Left speaker would be noticeably quieter than the right speaker ONLY when listening to CD's. When I switched to radio, however, the left speaker worked just fine. Then I got that nifty tip about hitting the left side of the console, and it worked!
Did your AC act up after that? GR6RR gave me a fair warning about my AC will going whacked out.
Old Jun 29, 2011 | 09:54 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
When the control board on the radio+a/c faceplate goes out, the a/c will be stuck at 60 degrees.
Old Jun 29, 2011 | 10:04 PM
willis555's Avatar
My AC did not act up at all. The only thing that happened after I hit the left side of the console was that the left speaker worked. Hope it works for you, too.
Old Jun 29, 2011 | 11:30 PM
Cooldude04's Avatar
Ack... Is it expensive to fix the problem bro?
Old Jun 29, 2011 | 11:32 PM
Cooldude04's Avatar
i'm crossing my fingers hope that my AC won't act up...
Old Jun 30, 2011 | 01:04 PM
willis555's Avatar
I don't see why it would. I feel like it would take more than a bump to upset the AC. I could be totally wrong though.
Old Jun 30, 2011 | 09:02 PM
Cooldude04's Avatar
Yes U R Right bro.. or at least, i hope you're right
Old Jun 30, 2011 | 11:38 PM
willis555's Avatar
So it worked??
Old Jul 1, 2011 | 04:25 PM
Cooldude04's Avatar
yeah. Everything works for now bro. I'm not quite sure how long they will last. Thanks for the reply
Old Jul 1, 2011 | 04:29 PM
willis555's Avatar
It works until it doesn't, to be honest. Then you just hit it again, and it works!
Old Jul 1, 2011 | 09:18 PM
Cooldude04's Avatar
I'll keep that in mind. I'm debating whether get a new HU or I should upgrade my exhaust system first..
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
Jeff T
Sep 30, 2015 02:00 PM
