New to G35 systems
Old Jul 19, 2011 | 02:02 PM
KnowScott's Avatar
JDM AC Controller/Trim Piece
Alpine INA-W910
Dynamat Extreme 35 sq foot
Diamond Audio H600S components
Metra 70-7550 Radio Wiring Harness
Metra Axxess ASWC Universal Steering Wheel Control
Metra 40-NI10 Nissan Antnna Adapter
PAC TR7 Universal. Trigger Module
Sirius-Xm SVX100V1 Xm In-Car Tuner and Antenna
Power cable, battery terminals, fuses, speaker wire, rca's, etc.
Already owned:
(2) JL Audio 12W3V2
JL 500/1 Slash amp
JL 300/4 Slash amp
Old Jul 19, 2011 | 02:25 PM
Rajen's Avatar
Usually the following remain the same:
1. Cost of the desired HU.
2. Dash Kit -- all are going to be over $100 since you will need to replace the HVAC controls.
3. Harness -- scosche or metra.
4. Antenna adapter -- scosche or metra.
The following he can cut costs:
1. Avoid the harness and splice wires.
2. Instead of 0/4 guage amp kit he can get 4/8 guage.
3. Instead of high power Class D amp he can get a class A/B even though power consumption isn't as efficient.
4. Don't have to go crazy with HIGH end cables.
5. If you're running less than 1000 watts total then you may not need the capacitor.
6. Read a lot of DIYs to do the labor yourself.
7. Exclude the Axxess steering wheel control module if you won't use it much.
8. Don't do a custom box. You can even get the kits where you assemble the enclosure yourself.
9. Don't have to buy EVERYTHING new. U can find some good used deals on Ebay, Amazon, or Craigslist. Even new closeout items are a good buy.
You can also sell some of your OEM equipment if you want to recover some of the costs.
--Rajen
Old Jul 21, 2011 | 02:52 PM
on1wheel01's Avatar
Im buying a g35 coupe next month I plan on throwing a killer sql setup in it. I wbuild speaker boxes myself so should get interesting. Here is the last one I built for a customer
Most likely all audio will consist of sundown audio equip.
Old Jul 21, 2011 | 02:53 PM
KnowScott's Avatar
Nice box... whats its tuned to?
Old Jul 21, 2011 | 03:03 PM
on1wheel01's Avatar
33 hz. What the customer wanted.
Old Jul 21, 2011 | 03:05 PM
KnowScott's Avatar
Whats the cubes and how long is the port? Looks like 2"?
Old Jul 21, 2011 | 03:09 PM
on1wheel01's Avatar
IIRC it was 3" port dont remember all the specs they are written down somewhere. I did it a month back. Been doing powder coating lately and holding off on speaker box build. Powder coating is fast and more money. Ill be gearing back up for boxes soon.
Built this one at the same time for same guy it absolutely slammed was for 2 sundown sa-12's, painted it black with texture looks like rhino lining.
Ill be doing a build log for my build when I get the car.
Old Jul 22, 2011 | 09:28 AM
KnowScott's Avatar
No flush mount double baffle?
Old Jul 22, 2011 | 12:01 PM
on1wheel01's Avatar
Fisrt box was flush mount second was double baffled.
Old Aug 15, 2011 | 06:27 PM
jake.millz32's Avatar
Does anyone have any recommendations on spare removal to fit subs more efficiently?
EnCr1pt3d
Jul 8, 2019 02:48 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
lemmy999
Jul 25, 2015 12:13 PM
laksjd84
Jul 24, 2015 05:12 PM
