Kicker subs defy laws of physics?
http://www.kicker.com/dvc_wiring
so i was looking at a solution for a problemon my stereo (il search then make a thread if i dont find anything on it ), but on my search i found this poster on some TampaRacing forums that said he could wire 3 subs to 1 ohm using DVC 2 ohm, or 2 ohm using DVC 4 ohm.
now i didnt pay too much attention in physics... but i do know my math, and there is no easy way to make 3 subs get equal power and have 1 ohm resistance using standard resistance voice coils.
So take a look at kicker's wiring diagram,and please tell me how their 3 sub configuration works.
I mean, they could possibly put variable resistances in? to make it work somehow? or mabye 1.333 ohms is close enough to 1 ohm to make it stable?
Or are kickers engineers mentally challenged?
While the latter is certainly possible, 1.333 ohms is stable if the amp can run 1 ohm. Technically you may draw slightly less power than the 1 ohm rating because you're not truly at 1 ohm, but you'll only run into trouble when you run below what the amp is rated at (i.e. 0.8ohm might give you trouble, the opposite is also true if you have a 4ohm rated amp you can easily run an 8+ ohm load, just without the full 4ohm rated power). You're essentially under utilizing the amp in that case, though probably not noticeably in the case of 1.333 vs 1.
FS[SoCal]: D/S 4080 Enclosure & JL Audio W6v2 10 inch
MrIP35
Audio/Video/Electronics
Nov 8, 2015 10:47 AM
