Amp and Speaker Replacement - Please verify
Old Sep 14, 2011 | 04:50 PM
trusty4104's Avatar
Hey - new to this forum, but not the Nissan/Infiniti family. Ive owned 2 4th gen Maximas, and 1 6th gen. Been on maxima forums for years, so I have a decent knowledge of cars...tho lacking in custom audio. I am replacing stock Bose amp and speakers, and I would like some feedback from seasoned veterans. Do not comment on the headunit.
1) What the **** happened to Bose? The stock systems in my 95/97 maximas were absolutely stellar IMO. What happened? They still used paper comes back in the day,so thats not the issue. I remembereach speaker had its own amp though. Could this be the cause? System in my 04 max and m G are pretty atrocious. Any insight?
2) I've already replzced the stock dor speakers and tweeters with Infiniti Reference 6030cs. Not great, but an Improvement. Next is addition of USA SPEC ipod adapter, amp replacement and remaining speakers. I am a 26 year old sales rep. I listen to mostly rock, some Wu tang family hip hop on occassion. Example: kings of leon - king of the rodeo. I am looking for improvements in overall volume, and tighter bass punch. Something as good as my old maxima. Please adviseon the following components:
http://www.amazon.com/JL-Audio-XD400-Amplifier-4-channel/dp/B0039AQVEM/ref=pd_sim_sbs_e_1
http://www.amazon.com/JBL-GTO628-6-5-Inch-2-Way-Loudspeaker/dp/B003KN2TEY
http://www.amazon.com/JBL-GTO928-6-Inch-9-Inch-Loudspeaker/dp/B003KN2TG2/ref=sr_1_1?s=electronics&ie=UTF8&qid=1316033266&sr =1-1
Willing to spend 300 on amp, 200for remaining 4speakers.
Old Sep 14, 2011 | 04:53 PM
trusty4104's Avatar
FYI - 2004 Graphite Coupe 5/at - Sport pkg, Premium pkg, Nav pkg
Old Sep 14, 2011 | 04:57 PM
eggyhustles's Avatar
Tight bass usually happens in the higher midbass octaves. Are your doors deadened and sealed? how much power are you giving the infinity's?
Infinty's usually have non-existant midbass, so that'll always be an issue.
You don't need 4 speakers. A pair of components upfront and a respectable amount of power will surprise the hell out of you.
Old Sep 14, 2011 | 04:58 PM
so you have 500
I would get
Image dynamics cxs 2 ohm
http://www.sonicelectronix.com/item_...v.2-2-ohm.html
On a good day, you can make an offer for like 250 and they'll accept it.
Soundstream stl 2.560
This will give you 280 x 2 @ 2 ohms
http://www.ebay.com/itm/SOUNDSTREAM-...#ht_4647wt_929
can't beat that for <125
Old Sep 14, 2011 | 06:20 PM
trusty4104's Avatar
much appreciated. what if i still want to replace the rear speakers?
Old Sep 14, 2011 | 06:39 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Deal with it later when you have more money to spend, but you won't miss rear speakers.
Old Sep 14, 2011 | 06:45 PM
Use the stockies for rear fill
Old Sep 14, 2011 | 07:34 PM
trusty4104's Avatar
I dont want to cut the pillars for the tweeters. Hurts resale value.
Old Sep 14, 2011 | 07:35 PM
trusty4104's Avatar
Also, does this amphave differential balanced inputs? I apparently need this feature due to stock HU
Old Sep 14, 2011 | 10:33 PM
You don't have to at all. I've got 1" tweeters sitting in the stock location using non-stock mounting.
Old Sep 20, 2011 | 09:55 PM
trusty4104's Avatar
Can I power the new components, AND the existing stock rear side panel and rear 6x9 speakers with that soundstream amp?
Old Sep 20, 2011 | 09:59 PM
no.
Delete the rears all together
With a 560w front stage, that whole car will be filled with sound and then some...
Old Sep 20, 2011 | 10:04 PM
Hotdawwgman's Avatar
hmmm interesting!
Old Sep 20, 2011 | 10:32 PM
trusty4104's Avatar
Originally Posted by eggyhustles
no.
sounds too good to be true, but i will probably end up doing it.
i assume, that if i wanted to keep the 4 rear speakers, i would need a 5 channel amp. correct?
Old Sep 21, 2011 | 04:55 PM
blazeplacid's Avatar
I have about 150rms on each side and there is no need for rear speakers.
The clarity and power of mids driven with a lot of power and correct placement and crossover points will drastically change your point of view
