vehicle speed sensor wire color and location!
Old Dec 18, 2004 | 10:38 AM
chisox_23's Avatar
hey guys,
i did a search but no clear answer.
my install guy just called and couldn't figure out the vehicle speed sensor wire location and color AND the reverse wire color and location.
please help as soon as possibe and i will keep searching on the forums.
i have a 2003 g35 coupe about to install a avn2454.
peace
sam
Old Dec 18, 2004 | 04:58 PM
KPierson's Avatar
First off, if your installer doesn't have access to this sort of information you really should rethink who you are letting touch your car. All professional installers should have access to a database that contains all of this inforation. If your installer doesn't have access to this information I would look for a different shop that does.
Speed sense: white/green its in a brown connector at the cluster - pin 19
The reverse light wire should be light green and should be running down either the passenger side or driver side.
Old Dec 18, 2004 | 05:27 PM
chisox_23's Avatar
damn, that's exactly what i told him,. his answer was his support was closed today.
thanks for the help.(kpierson)
i verified the speed sensor color and location.
but is the reverse light color right????
someone emailed me that it was purple /silver and found in the trunk under the trunk liner. please verify.
thanks
sam
Old Dec 18, 2004 | 07:41 PM
KPierson's Avatar
It can be found in numerous locations. The TCU transmits a signal to the reverse light relay. The reverse light relay then transmits a signal that goes from the relay through the main body harness (changes colors at that junction) and then goes to the light. Verify all wires before using them of course. I used the ESM to find the reverse wire, the database I have on my laptop is only for security/remote start. The ESM was also for an 03 Z, not G, but most of the wires seem to be the same color.
Old May 1, 2005 | 10:46 AM
aznluder's Avatar
Florida G35 Club Premier Member
Hey Kevin,
Quick question. Did you ever verify whether or not the reverse write is on the passenger or driver side? And when you say passenger/driver side, do you mean in the door somewhere?
Old May 1, 2005 | 01:24 PM
KPierson's Avatar
I never verified anything, I was just going off of the service manual. If I had to guess, I would say it was going down the passengers side, as in underneath the door sill (the wire goes from the BCM (I assume) to the rear reverse lights so it has to go the length of the car).
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
stay_tuned
Jul 21, 2015 07:09 PM
Jadenkid22
Jul 14, 2015 12:33 AM
