Speaker Wire to Rockford amp
Old Oct 7, 2011 | 01:18 PM
trusty4104's Avatar
I am connecting the Stock Bose HU to a Rockford Fosgate P400-4 Amp. It accepts differential balanced inputs via RCA.
Is this what I would use to convert the speaker wire into RCA?
http://cgi.ebay.com/ebaymotors/Rockf...ht_1420wt_1051
Old Oct 7, 2011 | 06:50 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Yea, that'll make it easy. $15 is overpriced though, MSRP is $7.99.
You can also easily just cut a regular RCA cable in half, strip and twist the wires inside and have one for under $2.
Old Oct 12, 2011 | 05:13 PM
trusty4104's Avatar
two more questions:
1) for that amp, am i better off using 4 ohm or 2 ohm speakers?
2) am i ok using this amp to power the stock bose speakers in rear side panels/deck for rear fill?
Old Oct 14, 2011 | 11:41 AM
blazeplacid's Avatar
4 ohm or 2ohm wont really matter in most cases
It can get really detailed down to the fact that some 2 ohm drivers are not as efficient as 4 ohm drivers.
Just depends on what you are looking for.
I purchased some LPG tweets and they are 6ohm and they are some of the best smoothest tweets I have heard. I think they are getting like 40 watts but the are efficient.
I would find a set of speakers you like at a price that fits your budget first. 2 ohm drivers in theory will draw more power from your amp, but not always.
yes you can power the stock speakers as long as the amp will run 2 ohm stereo, which im almost certain it will
Old Oct 15, 2011 | 01:33 PM
trusty4104's Avatar
I have Rockford fosgate p400-4 amp - going to run it at 2 ohms. Birth certificate says 123rms per channel at 2 ohms, and only 74 at 4ohms. Just bought image dynamics cxs62 v2 front components, and getting doors deadened...that's all I will be running for now. At some point I would like to put some kappa 6x9s in Or something similar, just for a poor mans low end. I would delete the rear side speakers all together. Sound plausible?
Old Oct 15, 2011 | 08:34 PM
Manhattan Project G's Avatar
Sounds perfect. Since the speakers are 2ohms (at least I think they are, double check that) and run at 25-125W RMS you can give them 100-123W RMS at the high end of your amp's capability and call it a day. You should be fine just disconnecting the rears, a lot of people do and it shouldnt hurt your sound experience not to have rears for now.
P.S. Based on what I can find your amp supplies 50W x 4 @ 4-Ohms, 100W x 4 @ 2-Ohms, so you'll be giving your speakers 100W RMS max - which should be fine.
Old Oct 16, 2011 | 03:46 PM
trusty4104's Avatar
Thats what they spec, but each amp comes with a birth certificate that details actual capabilities - in this case 123rms
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
