iPhone FM Transmitter question
Old Oct 16, 2011 | 03:25 PM
van_driver's Avatar
i have a 2004 coupe and the CD player stopped working about 6 months ago
Im thinking of buying an iPhone FM transmitter. I heard you can get these from walmart. Is there any brands I should consider?
Also, Ive never had one before, do you just plug it into that hole thats to the left of the glovebox?
Any other alternatives to this? I dont want to dish out over $1000 on a new set
thanks everyone
Old Oct 16, 2011 | 06:27 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
thanks everyone
The fm transmitters are garbage. The best you can hope for is adequate FM-reception quality. What can you really expect from a low-power transmitter that has to go through the airwaves to the antenna in your rear window?
For a discount alternative to a new radio, WIRED FM modulators are a good way to go - the sound quality is better than any FM station you've ever received, but below CD quality. PAC IS77 (about $41) and a set of antenna adapters ($12 for the required standard and reverse pack).
Installation is little more than connecting the power wires to the back of the cigarette lighter and plugging the antenna wires in the back of the radio and the antenna wire that went into the radio into the PAC IS77.
Old Oct 17, 2011 | 01:04 AM
moonsh0t's Avatar
Those FM transmitters have only worked well for me when I'm in rural areas. It might just be in my head though. They really are a waste of money.
Do this, it's much better... https://g35driver.com/forums/audio-v...irius-sat.html
Old Oct 17, 2011 | 10:35 AM
At the price to do that, you knight as well spend a little more and put an aftermarket radio in with substantially better features.
Old Oct 17, 2011 | 10:58 AM
moonsh0t's Avatar
$75-$100 for ipod integration vs. $650 for a cheap DD and JDM mount? $550 isnt just a "little more" to me.
Old Oct 17, 2011 | 11:42 AM
If you get a decent single din and metra kit from crutchfield, you can do it for under $200, if you install yourself. That's less than two tanks of gas more. And where these radios are notorious for failure, replacing it sooner than later is a good thing.
Old Oct 23, 2011 | 01:55 PM
cyrus32's Avatar
i use the go groove flex smart with my iphone in my g35. the sound quality is simply amazing for a fm transmitter, bought on it amazon for $$30 , i use a zip tie to secure it to the vent, works like a charm. bought it off amazon, after reading lots of good reviews, enjoy!
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
