Double din install sound low
Old Oct 18, 2011 | 12:56 PM
g35kid00's Avatar
So I installed my avic d3 double din this past weekend and the sound is pretty low idk. If I did something wrong but I just color mached the wires from harness to the PAC roem ... So I'm I stuck with this very low system or can I just save a little and buy a bass box like two tens and a amp and will my sound improve not just my bass ?????
On 40 on the volume it's like a little over half of what my stock radio kicked out this can't be normal
Old Oct 18, 2011 | 03:50 PM
saywat?'s Avatar
maybe something wrong with the deck?
Old Oct 18, 2011 | 06:29 PM
g35kid00's Avatar
No it's not that low its just not nowhere near loud and it's a little under stock sound but it does sound better than stock ... I think it's just the way it's suppose to
Be watever ... Now if I invest in a small
Set
Of ten subwoofer lets say jl's and a decent amp not expensive or cheap
But quality stuff will
My loudness go up or just the bass
Old Oct 18, 2011 | 06:31 PM
saywat?'s Avatar
yea u get a 4 channel amp itll sound louder. or make it simpler and get a 5 channel amp. alpine has a sweet reasonble 5 channel amp. sounds nice too.
Old Oct 18, 2011 | 06:40 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
The bose amp is by far the worst part of the stock system, so I support any plan that involves its removal.
Did you connect the ROEM to the RCAs or the speaker-level outputs?
Old Oct 19, 2011 | 07:08 PM
g35kid00's Avatar
the speaker level output im assuming i just mached the colors from the harness it sounds a little better now i guess i was expecting more but its still not loud how i would like
Old Oct 19, 2011 | 09:44 PM
saywat?'s Avatar
doesnt the speaker level converter have alittle **** on it to adjust the sensitivity. maybe u gotta increase it a bit. also pioneer decks have a high volume range up to 60 i think so 35-40 is about normal sound setting. so under normal use it will be at that volume. thats where mine is set to usually when im listening to music. i had an alpine and i think it only went up to 40 or something so i usually wouldnt go pass 25-30 or else its too loud
Old Oct 19, 2011 | 10:27 PM
g35kid00's Avatar
No no **** nowhere and the volume limit is 40 maybe it's just the shity Bose
Amp
I plan on changing it so hopefully that will fix it if not I have a problem
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
WillisFL
Dec 29, 2016 08:56 AM
EPG35
Aug 16, 2015 04:52 PM
itztwinki3
Aug 1, 2015 12:58 AM
kd03g99
Jul 30, 2015 11:24 AM
